Old 06-05-2016, 08:13 PM   #1
2017 25' Flying Cloud
1964 17' Bambi II
Ogden , Utah
Battery disconnect switch
We have a 2016 22' Sport. We're confused, when do we use the battery disconnect switch off & on? We park the trailer in our insulated, totally inclosed pole barn & hook up to shore power. We have 2 new 6 volt deep cell batteries. Thank you for your help.
mcaslaon4449 is offline   Reply With Quote
Old 06-06-2016, 11:14 AM   #2
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
The problem with the Store/Use switch is while in Store mode there is still some battery draw from the LP Leak detector so after a couple of months the batteries could be drawn down to unsafe levels.
The problem with the OEM charger/converter is its not a 3 stage charger that monitors the state of the battery. It will continually charge the battery causing the water to eventually boil out if kept on charge. To solve this issue an converter upgrade is needed such as the Progressive Dynamics PD4655.
You could turn the the Use/Store switch on for a week then off for a week. The trouble is on shore power the LED is light for Use and Store modes so hard to tell unless you put a multimeter on the battery to see if its at 12.x or 13.6v from the charger.
If you know the batteries are fully charged you could put the Use/Store to Store and just disconnect the negative cable and leave the trailer on shore power to power 12v on the trailer.
Kelvin
Old 06-06-2016, 11:22 AM   #3
2015 30' Classic
Pleasanton , California
The 2016 sport manual says this model includes a three-stage battery charger/converter, so if that's true (check the converter model) there's no need to replace your converter and you can happily leave your trailer connected to shore power. Select the Use position to charge your batteries from your converter.
When I'm boondocking I like to select the Store position to make sure I disconnect all my loads from the batteries.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 06-06-2016, 11:50 AM   #4
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
A simple solar charger can offset the small drains that naturally exist. For less than $150 you can get a pv panel and a name brand controller to keep everything topped off and happy.
Old 06-06-2016, 11:58 AM   #5
KJRitchie's Avatar
2008 25' Classic
So, finally Airstream is installing 3 stage converters starting for the 2016 models?
Kelvin
Old 06-06-2016, 12:34 PM   #6
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
Following....
Steve "Centennial Man"
centennialman is offline   Reply With Quote
To disconnect or not to disconnect urnmor Towing, Tow Vehicles & Hitches 36 02-22-2017 10:24 AM
Battery Disconnect Switch Not Working Toronto_Guy Batteries, Univolts, Converters & Inverters 9 04-13-2015 05:39 PM
Battery Disconnect Switch Question MaryD Batteries, Univolts, Converters & Inverters 4 07-13-2013 08:19 AM
Battery Disconnect Switch nsbcpa Batteries, Univolts, Converters & Inverters 5 08-10-2012 05:11 PM
Battery Disconnect Switch, Solar & AGMs SilverGate Batteries, Univolts, Converters & Inverters 29 11-03-2010 10:52 AM
