12-10-2016, 01:44 PM
Journeyman
2016 25' International
Amherst
, Massachusetts
Battery Disconnect: Please check my work?
Gang,
I attached two battery disconnects today but I'm a newb and I have no idea if I did it right. Can you take a look at this photo and tell me what you think?
Thanks!
12-10-2016, 02:39 PM
Naples
Originally Posted by thiel
Gang,
Attachment 276535
Thanks!
Both negative leads (inverter and coach DC supply) on the disconnects......looks OK to me.
lewster
12-10-2016, 02:53 PM
Journeyman
Amherst
, Massachusetts
Thanks Lewster... so when I disconnect where do I test with a voltage meter to make sure I'm good?
12-10-2016, 03:07 PM
2002 30' Classic S/O
Fleming Island
I don't know that it makes any difference but the positive paralleling jumper is on the battery terminals and the negative jumper is on the disconnects. I would think you would want parallel batteries to always be connected in parallel.
Al
12-10-2016, 04:48 PM
Journeyman
Amherst
, Massachusetts
Al
Ha! I don't know what any of that means! :-)
12-10-2016, 06:00 PM
1969 31' Sovereign
Broken Arrow
, Oklahoma
Your batteries are connected in parallel so the batteries are still connected together but disconnected from the everything else. This is a good disconnect from the 12v stuff inside however, should one battery be bad it could drag the good battery down with it. To prevent this you could just disconnect the smaller black wire on the negative side on either battery and connect it back when you want to use it again..
As it is you did good no need to measure just go inside and turn on any 12v light or water pump they should not work.
Garry
12-10-2016, 06:07 PM
Journeyman
Amherst
, Massachusetts
Thanks!
12-11-2016, 07:19 AM
Naples
Al
Actually, his negative parallel cable seems to be placed on the negative disconnect terminal, so when he activates the disconnects, the batteries will also be isolated from each other.
As a result, if you want to test battery voltage when disconnected, measure each battery individually (which is the only way to see the condition of each battery).
lewster
12-11-2016, 11:24 AM
2016 23' Flying Cloud
Hillsborito
, Oregon
On a side note, what brand are those? I'm curious to know what others use
12-11-2016, 12:19 PM
Journeyman
Amherst
, Massachusetts
Bought them on Amazon. Lowest bidder!
12-11-2016, 12:37 PM
Fleming Island
That's what I was trying to say, Lew, but I was wondering if that was desirable. Shouldn't parallel batteries always be connected in parallel to maximize the chances that their characteristics would't drift apart due to aging? I don't know which is preferred and I was hoping you would weigh in.
Al
12-11-2016, 12:49 PM
Journeyman
Amherst
, Massachusetts
I put the trailer away today and checked the batteries after they were disconnected. One said 12.22 and the other said 12.21.
First: is that good ...or did I get batteries with lot rot? (They have been charging for days..).
Second: I'm going to check them in a week or so and let you know my real world experience with Idroba's advice.
12-11-2016, 12:56 PM
2016 27' Flying Cloud
Hartsburg
, Missouri
So if you are using a battery disconnect to get rid of parasitic loads so your batteries don't discharge, do you need a disconnect on the negative lead for the inverter or just the dc supply?
Frank & Fran
2016 27' FC FB with 600 W solar
2016 Ford F150 EcoBoost
Equalizer Hitch
12-11-2016, 12:57 PM
Naples
Al
Not really. When I store batteries, I always isolate each electrically so that 'if' one gets a bad cell it won't pull down the other.
Lew Farber
lewster
12-11-2016, 01:10 PM
2016 25' Flying Cloud
Jupiter
12.2 volts is ~60% charge. You don't want to let them discharge much more than that.
12-11-2016, 01:55 PM
Journeyman
Amherst
, Massachusetts
So...if they have been charging for days and are only at 12.2 ...sounds like they are just not in good shape...?
Before I used the tongue jack they were at 12.59. Not much better.
12-11-2016, 04:18 PM
Naples
What are you using as s charging source???
Lew Farber
lewster
12-11-2016, 05:17 PM
Journeyman
Amherst
, Massachusetts
Lew Farber
Just the airstream itself.
12-11-2016, 05:49 PM
Naples
Bad....bad....BAD!!!!
Your batteries get a continual 13.6VDC whether they need it or not, this leads to severe undercharging (many liquid cell batteries require a bulk/absorb charge of up to 14.8VDC to get FULLY CHARGED) and in some miracle IF they are fully charged, that same 13.6VDC will not allow the batteries to float, meaning that they then get OVERCHARGED!
You need a better charger, especially if you intend to ever upgrade your batteries!!!
lewster
12-11-2016, 07:16 PM
Journeyman
Amherst
, Massachusetts
Haven't gotten to it yet. Only just got the trailer in mid-November...
