Old 06-17-2013, 05:14 PM   #1
JohnGough's Avatar
2011 19' Flying Cloud
Waterloo , Ontario
Battery Disconnect - newbie/simple question please....
My battery disconnect light is always on - whether on shore power or battery power.... is this standard. Not really covered in my manual. If the light is always on, what is the purpose of having a light?
thanks in advance.
J.
JohnGough is offline   Reply With Quote
Old 06-18-2013, 05:08 AM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Is it on when you have the battery disconnected AND shore power is unplugged? The light probably indicates that you have power going to the trailer's 12v systems, regardless of the source of the power. If you unplug from shore power and turn off the batteries, the light should go out.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 06-18-2013, 07:54 AM   #3
Free Range Human
Drathaar's Avatar
2012 25' FB Flying Cloud
Twin Rocks , Oregon
thanks in advance.
J.
That's normal. The light should be out when you are not on shore power, and you have pressed the battery disconnect switch. If it remains on then, you've got a problem.
Old 06-18-2013, 09:06 AM   #4
SilverGate's Avatar
2007 23' Safari SE
San Diego , California
More about the Battery Disconnect Switch:
Battery Disconnect Switch, Solar, and AGMS
SilverGate is offline   Reply With Quote
Old 06-18-2013, 04:35 PM   #5
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
The "Store/Use" nomenclature has caused a lot of us to scratch our heads!
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 07-01-2013, 08:02 PM   #6
Lexington , Kentucky
Yes, been there, done that. I ruined a set of batteries because I thought I was charging them on shore power, because the red light was on. Only two months later did I realize that the batteries were not connected. After completely draining the batteries they couldn't be coaxed back to life. As usual, I learned about the red light's operation the hard way.
wlanford is online now   Reply With Quote
