Old 08-20-2015, 06:20 PM   #1
1979 28' Airstream Excella 28
Brooklyn , New York
Battery dies after 2 days of sitting
I can't figure out what is causing the starter battery to die after two days of sitting. I have a 1979 Excella Motorhome. Something must be pulling energy while it sits because I just put a brand new alternator in it.
Walkietalkie is offline   Reply With Quote
Old 08-20-2015, 06:26 PM   #2
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Could be a bad battery or could be something causing parasitic current draw. A simple check with a digital volt meter can tell you if current is being drawn from the battery while the vehicle is sitting. If that is the case, you will have to check each circuit one at a time (pull the fuse) and see if the current draw stops. That will narrow down the cause. Good luck.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
68 TWind is online now   Reply With Quote
engine dies, during warm up and after starting? John H. General Motorhome Topics 29 05-06-2014 04:18 PM
Battery charge rate after sitting 6 months idroba Batteries, Univolts, Converters & Inverters 4 04-09-2013 02:58 PM
Suggestions on Starting Generator after sitting 92landyacht Land Yacht/Legacy Motorhomes 30 12-04-2011 04:25 PM
Took it out this weekend after sitting for the winter Lothlorian General Repair Forum 1 04-13-2009 09:03 PM
1957 Overlander towing after 12 years sitting on the same site. HELP! SUEHOWIE Tires 25 10-21-2008 10:36 PM
