Old 07-11-2009, 09:36 PM   #1
APB
APB's Avatar
1978 31' Sovereign
Escondido , California
Battery connector
I just figured out that it is easier for me to remove my batteries for charging during long term storage. I have a '78 Soverign. Does anyone have a line on where I can find a couple of the quick disconnect plugs used in this era Airstream?
I would like to make a wiring harness to connect both batteries in parrallel to my battery charger.
APB
Bluegrass is flat picking good!
APB is offline   Reply With Quote
Old 07-12-2009, 08:57 AM   #2
Iwannagocamping
Dakota's Dad's Avatar
Rineyville , Kentucky
Tagging along, because i would surely like to find a source for the other half of this myself...
See our blog here on how two RV/AS rookies tackle a 1979 Sovereign resto!!
Just the photos.. (sometimes you don't need the blog, just a picture worth a thousand words..)
1979 Sovereign International
2004 Ford Expedition Eddie Bauer
2 Golden Retrievers
Air #36788
TAC#3179
WBCCI #1265
Dakota's Dad is offline   Reply With Quote
Old 07-12-2009, 09:43 AM   #3
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I am no expert on battery charging, but I believe that you really need two chargers or a charger with dual outputs rather than running the batteries parallel off of the charger. I have experience with my bass boats and the chargers all have dual outputs. I think that a single charger will read the charge state of the first battery and the second battery will not fully charge.
The new chargers that are out there for tolling motor batteries have 2 or even 3 outputs and they will charge and maintain multiply batteries properly. Bass Pro has several listed.
Old 07-12-2009, 03:05 PM   #4
APB
APB's Avatar
1978 31' Sovereign
Charging in together is correct as it helps keep the batteries matched.
If you charge each separately you end up with batteries of different capacities trying to work together with one battery working harder than the other.
Also this is how they are charged when in the trailer.
APB
9 to 7 Pin Connector Lufletch Electrical - Systems, Generators, Batteries & Solar 7 07-22-2014 07:36 AM
Adapting a 7 pin vehicle connector to a 9 pin Airstream connector PatandLane Lights - Interior & Exterior 3 03-22-2009 07:09 PM
2nd Battery/7-way connector wbrownrr Electrical - Systems, Generators, Batteries & Solar 8 05-19-2005 05:22 PM
Help with Telephone Connector seamusthegray Our Community 3 09-20-2004 07:58 AM
Battery connector TomW Batteries, Univolts, Converters & Inverters 2 04-01-2004 01:35 PM
