Old 05-22-2017, 09:58 PM   #1
gaylejoe's Avatar
2007 25' Safari FB SE
St. Hedwig , Texas
Battery Connection
Would appreciate someone post a photo of the battery connection on the Airstream. I need a photo showing the battery connections.
gaylejoe is offline   Reply With Quote
Old 05-22-2017, 10:15 PM   #2
Dobber's Avatar
2012 25' FB Flying Cloud
Queens , New York
I can forward in the AM ...
A photo of mine and a drawing, if you still need.
Dobber is offline   Reply With Quote
Old 05-23-2017, 07:38 AM   #3
Dobber's Avatar
Queens , New York
PM me if you need a translation.
ID:	286100   Click image for larger version
Old 05-23-2017, 10:07 AM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
All positives, Red Wires, together and all negatives, Black Wires, together.
Just make absolute sure you connect all the Red wire connections before you connect any Black wire connections at the battries. Failure to do it this way can result in one hell of an explosion if your wrench, while on a red wire, touches the trailer body.
2004 Excursion 4x4
Old 05-23-2017, 10:11 AM   #5
Caffeinated's Avatar
2015 27' Flying Cloud
Portland , Oregon
One hell of an explosion? I don't think so. A bit of spark maybe.
Mike
Caffeinated is offline   Reply With Quote
Old 05-23-2017, 10:26 AM   #6
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Mike
I think a wee bit more than a bit of a spark.
Old 05-23-2017, 10:37 AM   #7
gaylejoe's Avatar
St. Hedwig , Texas
Battery Connections
The only wire I have a question about is the black wire coming from the jack. I have a picture on my phone of my connections but unable to post from my phone.
Old 05-23-2017, 10:37 AM   #8
HowieE's Avatar
Images: 12
Sorry Mike you clearly have never shorted out a wrench against the body. If you consider the possibility of melting the wrench a "Bit of a Spark" I would yield to you.
2004 Excursion 4x4
Old 05-23-2017, 10:44 AM   #9
HowieE's Avatar
Images: 12
You have found the exception. The Black wire coming from the jack is in fact the Hot wire and goes to the Red battery terminal.The jack is grounded through the trailer frame which is connected to the negative, Black, battery terminal.
If you had connected the jack wire to the black terminal the jack would not work as both sides would have been connected to ground.
2004 Excursion 4x4
Old 05-23-2017, 11:08 AM   #10
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Here's a view I took of mine from curbside (thus making the C with my hand to remind me). The jack's power cable is black and goes to a red positive terminal.
Old 05-23-2017, 11:55 AM   #11
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
If your 2007 Safari is like my 2008 Classic 25fb my two batteries only had the positive and negative leads, a two parallel cables. My power jack cable terminates on the positive bus inside the trailer. My trailer had no inverter so not extra wiring to the battery.
Kelvin
Old 05-24-2017, 08:31 PM   #12
gaylejoe's Avatar
St. Hedwig , Texas
Thanks everyone. I had it connected corrected after all. Just wanted to make sure. Thanks very much for the input.
Old 05-24-2017, 08:52 PM   #13
Boxite's Avatar
2008 22' Sport
I once watched an experienced mechanic, while adjusting tappets using a 14" feeler-gauge, accidentally lay that feeler across the batt terminals. In only a moment that feeler became incandescent and gave him a third-degree burn of the hand and acid all over the area as the battery blew it's caps.
Disconnect the ground-cable anytime one is working in the vicinity and keep all metal tools away from the battery. Use battery wrenches on batteries. (They are short and insulated.)
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
Old 06-07-2017, 10:32 AM   #14
Mahomet , Illinois
Wire Question
What does the black wire with yellow fitting go to?
Jhandley is offline   Reply With Quote
Strange connection from inverter to battery mikextr Batteries, Univolts, Converters & Inverters 5 05-31-2014 11:16 AM
Strange connection from inverter to battery mikextr Electrical - Systems, Generators, Batteries & Solar 1 05-28-2014 09:19 AM
Battery Connection / Inline Plug Andreasen Batteries, Univolts, Converters & Inverters 6 05-12-2010 01:46 PM
plug-in battery connection racoco 1974 - 1979 Sovereign 3 10-22-2006 10:17 PM
puzzled by fuse at battery connection Tin Tortuga Electrical - Systems, Generators, Batteries & Solar 2 03-25-2005 04:13 PM
