Old 09-16-2007, 07:56 PM   #1
SteveH's Avatar
Common Sense , Texas
Battery Compartment Door
I just bought a '75 23' Airstream, and on the way home with it, the drop down battery compartment door along with the battery fell off. Of course I did not notice it until I was some miles down the road.
Anyone have any idea where I might be able to get another battery compartment door? They are out of production at Airstream.
Thanks for any input you might have.
Old 09-18-2007, 05:27 AM   #2
Silver Lamb
EweMama's Avatar
1969 27' Overlander
1961 16' Bambi
Bonner Springs , Kansas
Bummer! Where is the battery compartment door located exactly on the '75?
EweMama is offline   Reply With Quote
Old 09-18-2007, 06:02 AM   #3
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Not to sound discouraging but you'll need some good luck to find one of those. I watch Ebay - think I've seen one in the last couple of years. Did you find the door and it's just beat up....
Old 09-18-2007, 06:09 AM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The Safari should be the same as my TW. It is located aft of the axels on the curb side. In this picture you can see the rear Bal jack.
These doors will pop open if the battery is not secure in the compartment. I guess what happened at that point was the battery landed on top of the door and detached it from the trailer. I had the door open once on a trip. I modified the stap to hold it in better and it has not been a problem since. Good luck finding a door.
Richard
Old 09-18-2007, 06:32 AM   #5
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
See my exact same problem here Airstream Forums - View Single Post - Rivet Alert--trim bands
I was lucky--the door support cables retained the door and the only real damage was losing the battery. Maybe we should replace the aluminum rivets on the hinge with steel. Would that be significant corrosion problem?
Zep
Old 09-18-2007, 06:59 AM   #6
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Yes, replacing the rivets with steel could cause future corrosion. Installing a higher count and better alloy aluminum rivet would most likely solve the problem, and of course proper running gear balance.
Kip
Old 09-18-2007, 09:39 AM   #7
SteveH's Avatar
Gary,
No, I didn't go back because at the time I noticed it missing, it could have been a hundred miles behind me.
Yep, the "dealer" did not have the battery straped down, just in there and I didn't know the difference. I'm still looking for one and hope I don't have to fabricate something as it would not be pretty.
I'm very disappointed in the dealers lack of enthusiasm in the situation. Guess it's the typical "tail light warranty" you get with anything used. Funny, he did sing a different tune during his sales pitch.
Old 09-18-2007, 09:48 AM   #8
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
There have been references here on the forums to A/S salvage yards in various parts of the country. You might try a search for those threads. You may get lucky.
Dave
Fyrzowt is offline   Reply With Quote
Old 09-18-2007, 11:21 AM   #9
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
For something that's going to be that hard to find - believe I'd make the 100 mile drive and look for it. Rent a couple kids to watch for you and offer them $20 for the one who spots it.....
Old 09-18-2007, 12:59 PM   #10
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I have acess to a 75 Tradewind wreck. Don't know if the door is there but I can check. I'm not sure when I will get to it but need to get some other parts. Let me know if you still need it and keep in touch. You might want to check the locks are tight on your other compartments.
Old 09-18-2007, 02:46 PM   #11
SteveH's Avatar
Ganglin,
That was 100 miles from the time I noticed it, since then I am another 750 miles farther.
However, finally some good news, I just got back from a place here in Texas that deals in used Airstreams (some very used I observed), they had one, and I bought it. It's not perfect, but it can be cleaned up and will be much better than what I would have fabricated. You can bet it will be fastened so it will not come off this time.
Thanks for everyone's input.
Steve
Old 09-18-2007, 03:26 PM   #12
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Congratulations on finding one so soon.
Old 09-18-2007, 06:35 PM   #13
Steve
Steve,
Would you mind sending me the contact info for the dealer in texas? We're in need of a couple of used parts ourselves.
Thanks!
Old 09-19-2007, 12:09 PM   #14
SteveH's Avatar
Brad,
They are in Bastrop, TX, and here's the phone number: 512-718-1930
Good luck.
Steve
Battery compartment lock. crazylev Batteries, Univolts, Converters & Inverters 7 02-29-2008 05:02 PM
Ha! What Battery Compartment??? (Pics) sierrajb All Argosy Trailers 14 01-01-2008 10:15 PM
Battery Compartment Sundance Batteries, Univolts, Converters & Inverters 10 07-14-2007 11:56 AM
Battery compartment...How to? Rog0525 Electrical - Systems, Generators, Batteries & Solar 4 06-17-2003 10:58 PM
Battery Box Compartment AccessMaster Airstream Motorhome Forums 11 05-03-2003 09:00 PM
