Old 07-11-2007, 09:13 PM   #1
Devils Lake , North Dakota
Battery Compartment
I have a 26' Argosy with a rather small battery compartment. Is there a larger interior "box" I can retro fit??
Or can I just pull the black plastic box out and buy some kind of sealed, vented box that would accommodate a larger battery.
And I am not going to AGM's Just way to expensive.
Sundance is offline   Reply With Quote
Old 07-11-2007, 09:37 PM   #2
bobkelly's Avatar
2003 22' International CCD
Whittier, California , Depoe Bay, Oregon
Sundance----By the time you factor in the costs with retro fitting a box, the AGM batteries may look attractive enough, cost wise. Their other positive characteristics may come almost "free" in the total cost analysis.
2003 22ft CCD Int'l
2005 GMC Yukon Denali
WBCCI #2960
bobkelly is offline   Reply With Quote
Old 07-11-2007, 10:05 PM   #3
Here's an option that might work??? 2 regular batteries would outperform 1 AGM I would think. This set up would run about $175 including batteries.
I welcome any and all advise here......... Thanks
eBay Motors: Double Battery Box Optima Drag Race IMCA Sealed (item 320136370786 end time Jul-16-07 19:16:31 PDT)
Old 07-11-2007, 10:09 PM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
That is a very nice box, where do you mount it? Since it is not vented it can not go inside the trailer.....
Richard
Old 07-11-2007, 10:13 PM   #5
It will be vented indeed. In fact better than the existing stock box I think.
Old 07-12-2007, 04:39 AM   #6
fastrob's Avatar
1976 25' Tradewind
. , AZ to Maine
Plastic?
I like plastic.
The metal will conduct electricity.
Have you looked at a marine supply or even a Wal Mart for battery boxes?
Our batteries are in the plastic boxes from Wally World, cheap, vented, easy to tie down and cables can come out the top.
We use them for electric fences, boat and Airstream.
R
"Talk is cheap, Airstreams are expensive," Wally Byam.
fastrob is offline   Reply With Quote
Old 07-12-2007, 06:29 AM   #7
mandolindave's Avatar
I had that problem with the small batt box
The problem was also that the door to the compartment was too small. It was going to cost mega bucks to enlarge the door and vent. So I went with the AGM's and was able to upgrade to two batts.
mandolindave is offline   Reply With Quote
Old 07-12-2007, 07:21 AM   #8
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
2 Questions:
1. So AGMs don't need to be vented?
2. Will the OEM Univolt in early 70's keep 2 batteries charged?
Old 07-12-2007, 10:14 AM   #9
My understanding is AGM's need venting as much as lead/acid.
As far as the Univolt......... I've heard it's wise to trash it and get the newer units like InteliPower.
Old 07-14-2007, 11:19 AM   #10
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Actually, AGM batteries DO NOT require venting at all. The are sealed and require no maintenance whatsover. That's the advantage of them. The disadvantage is cost. They are expensive but worth it. When my Trojans die, I'm buying to AGMs.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 07-14-2007, 11:56 AM   #11
I was told that AGM's have a release valve that triggers at 2 psi and will vent at that time.
I have decided to go the AGM route but with a battery box (Walmart plastic one) and a small vent to the outside.
Battery Location uwe 1970-79 Tradewind 23 12-02-2015 07:41 AM
replacing compartment locks Dave Cole Exterior Storage Compartments & Access Doors 3 08-14-2008 07:34 PM
Battery Slide Out niftypkg Electrical - Systems, Generators, Batteries & Solar 5 01-01-2003 03:41 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
62 Bambi Battery sbboyd Electrical - Systems, Generators, Batteries & Solar 5 09-20-2002 07:33 AM
