Old 05-17-2004, 06:45 PM   #1
Kistler's Avatar
2002 25' Classic
Oro Valley , Arizona
Battery check--why don't I ever have to add battery water?
Have owned my tt for almost 2 years now and check the battery water and I never have to add water.
Am all prepared with my wife's old turkey baster and distilled water and I check every few months and the level never changes.
Is this normal? Tucson is pretty low humidity most of the time; I don't get it.
Kistler & Brenda
2002 Classic 25'
2003 Expedition EB 5.4L, AWD, AdvanceTrac Class IV hitch pkg. Reese dual cam/Prodigy
Kistler is offline   Reply With Quote
Old 05-17-2004, 06:59 PM   #2
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
You must be charging your batteries correctly and water, which condenses on the inside of the caps, is being returned to the battery. Overcharging leads to boiling off of the battery acid/liquid.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 05-17-2004, 07:03 PM   #3
Kistler's Avatar
2002 25' Classic
Thank you Craig, I gotta "D" in Physics in HS and did not take Chemistry.
Appreciate your reply.
Kistler Ryan
Tucson
Old 05-17-2004, 07:27 PM   #4
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
I second Craig's post.
Newish trailer, newish battery, near perfect charging system.
Uwe
www.area63productions.com
Old 05-17-2004, 07:31 PM   #5
Kistler's Avatar
2002 25' Classic
And thank you, Uwe, for seconding that!
K
Old 05-17-2004, 07:43 PM   #6
davidz71's Avatar
1986 25' Sovereign
One thing I did before buying new batteries was to "bone up" on Battery Maintenance 101. I studied the different types of batteries and was thinking that four Trojan 6 volt batteries would be the ideal way to go due to extra amp hr ratings. I learned that they made special caps that allowed the water to condense on the inside and it was returned to the supply. I would have never thought about that. All I had to do was look at my two battery compartments on the front of the trailer and knew that there was no way I could fit four 6 volt batteries on the tongue because my disc brake booster and other components were there. Oh well.
I opted to buy two of the 105 amp hr. grp 27 batteries (found that not all of the grp 27's fit) and do the best job of charging them right. I have since found that I could have used two Trojan 12 volt batteries rated at 115 amp hours but that is OK. I have had good luck with the 1 amp BatteryMinder product so I ordered the 4 amp model and hooked it up several days ago. I sure am sold on what it does.
Craig
AIR #0078
3.73 rear end
Old 05-17-2004, 07:59 PM   #7
Kistler's Avatar
2002 25' Classic
Craig, that is really a pretty Excella you have. Envious here
K
Old 05-17-2004, 08:42 PM   #8
davidz71's Avatar
1986 25' Sovereign
Thanks for the comments. Now that most of my garden is in, I can start polishing her so that she is better than when I picked her up in AZ.
Craig
AIR #0078
3.73 rear end
Old 05-17-2004, 09:03 PM   #9
gklott's Avatar
2004 30' Classic
Johnson City , Texas
Images: 83
Just checked our batteries after the first 10 months. Ok, but slightly less of a level than I normally have in marine batteries.
Added about 1-2 oz. per cell to bring them up to slightly below the bottom of "tubes" going down inside the battery, which is about 1/4 to 1/2 in. above the plates. Seems to be about what everyone recommends. A little bit more is better than not enough.
Figured that's not bad for the first year, and I doubt I will need to add much more.
73/gus
Gus - KR4K : Mary - K5MCL
2004 30ft. Classic
2017 Infiniti QX80 Limited
ProPride 3P/Prodigy P3
gklott is online now   Reply With Quote
Univolt reminder ** Battery Check! Sav'h Steve Batteries, Univolts, Converters & Inverters 21 10-07-2003 02:18 PM
Checking water in the battery... drboyd Electrical - Systems, Generators, Batteries & Solar 1 08-15-2003 09:37 PM
water system mystery garymacf Plumbing - Systems & Fixtures 4 06-21-2003 11:50 AM
Battery Exploded wayner1239 Electrical - Systems, Generators, Batteries & Solar 15 05-11-2003 08:43 AM
Could Water Heater Tank Be Filled with Junk? heyskipper Water Heaters, Filters & Pumps 4 03-17-2003 07:26 AM
