Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Batteries, Univolts, Converters & Inverters
Old 10-17-2004, 01:31 PM   #1
andoboba's Avatar
Profile:
Cool Battery Charging with Univolt?
I need to have my '69 Ambassador plugged in full time. Has anyone figured out how to safely charge the battery while leaving the Univolt constantly plugged in? It seems like lots of batteries are overcharging and thus prematurely failing. Also lots of corrosion from boiling battery. Someone has to have figured out an external "smart charger" that you can hook between the Univolt and the battery. Does anyone have a link or a product that is available to make this work? Thanks!!
If there are other problems with leaving things plugged in full time that I am not aware off please chime in.
1969 29' Ambassador International
1994 K20 Suburban w/7.4l
1966 K25 Fullsize Truck w/5.7l
andoboba is offline   Reply With Quote
Old 10-17-2004, 02:56 PM   #2
garry's Avatar
Profile:  1969 31' Sovereign
Broken Arrow , Oklahoma
common problem
This is a common problem with the Univolt. I use a battery disconect and from time to time allow the battery to charge as needed , others use a timer between the battery and Univolt do a search and you will find several solutions up to replacing the Univolt.
The disconnect I used is pictured, purchased at a marine store.
Garry
garry is online now   Reply With Quote
Old 05-24-2009, 08:31 PM   #3
Profile:  1977 31' Sovereign
Manchester , New Hampshire
Images: 33
Garry
Another solution is a plug in heavy duty timer for appliances have the univolt run like 2 hours a day to keep batteries full but not over charge them . I used this method before I got my 9100 . It did good job .
1976 Airstream Sovereign International Landyacht (renovating)(found DOM plate said 1976)
1968 Airstream Caravel 17 footer
2004 Nissan Titan with BT package
K/N Cool intake air
Duel power exhaust
Mrcrowley is offline   Reply With Quote
Old 10-17-2004, 05:26 PM   #4
Profile:  1975 29' Ambassador
Reno , Nevada
Dump the univolt and upgrade to a intellicharger with charge wizard (or equivalent) see
http://www.airforums.com/forum...ead.php?t=7427
these go as a pair and run about $200 - $250
http://www.campingworld.com/browse/s...m?skunum=17298
http://www.campingworld.com/browse/s...21995&src=CROS
The key is that you want to cover two separate needs. The first is charging the battery. This is best done with a three phase battery charger. The second is battery maintenance. This needs something that can equalize the battery and keep the float at the right level.
also see
http://sierranevadaairstreams.org/ow.../charging.html
Old 12-03-2004, 09:06 AM   #5
Mike76251's Avatar
Profile:
If your concerned about corrsion from batteries get a Optima.......they are sealed at the posts.
Unlike all the other batteries out there.
Man......I sound like I work for them but i don't.
I just love their batteries.
Mike
Mike76251 is offline   Reply With Quote
Old 12-03-2004, 09:22 AM   #6
andoboba's Avatar
Profile:
Blue Top Optima
I too have Optima blue tops and a red top in my Suburban. I love these batteries but have found out a few things of interest. These will die while being constantly charged by the old univolt even faster than the "wet" batteries. Very sensitive to charge rate! If you overcharge an Optima they will vent out their sealed vents and are usually ruined at that point. Change out your electronics and make sure to get a "gel cell" charge wizard. I went through all this a while ago and am happy with the results.
Old 12-03-2004, 09:57 AM   #7
RoadKingMoe's Avatar
Profile:  2001 34' Limited
Beavercreek , Ohio
For a given standard battery size, i.e. Length X Width X Height, the spiral-wrap, "six-pack" design of the Optima doesn't contant nearly as much battery (i.e. lead), and as a result, has considerably less capacity than a conventional AGM. You can see that in the weight. A yellow-top Group 31 Optima only has about the same capacity as a smaller Lifeline Group 24. Optima also does not offer a Group 27 size, and their Group 34 is just a shorter, and less capable Group 24 sized battery.
Code:
Lifeline AGM GPL-31T  105AH   195 min RC (81.3AH)   69 lbs
Optima AGM   D31       75AH   155 min RC (64.6AH)   60 lbs
Lifeline AGM GPL-24T   80AH   149 min RC (62.1AH)   56 lbs
Optima AGM   D34       55AH   120 min RC (50.0AH)   44 lbs
Lifeline AGM GPL-27T  100AH   186 min RC (77.5AH)   65 lbs
AH rating is at the 20-hour discharge rate (AH/20)
RC is Reserve capacity in minutes at a 25 amp rate.
Don't confuse AGMs with gel cells, which need a lower than traditional bulk charge voltage to prevent thermal runaway. An AGM, Optima, Lifeline, or other brand, should work with any good 3-stage charger designed for flooded cells, and that includes the Charge Wizard. Using a gel-cell Charge Wizard just results in slower charging.
I agree with Bryan. Whether you go AGM or not, pitch the Univolt and get an Intelipower with Charge Wizard.
Maurice
AB8XA
AIR # 804, WBCCI 5446
The Long, LONG Trailer
Paralleled Honda EU2000i
Old 12-03-2004, 10:39 PM   #8
Silver Hilton
Mark Wiltrakis's Avatar
Profile:  1992 29' Excella
1959 24' Tradewind
Hillsboro , Oregon
I'm at the point of replacing my deep cycle batteries, and am sold on the advantages of AGM's. I have the original '92 "Univolt" (which I think is actually Magnatek) convertor in my trailer. Should I pitch it and go for the Intellipower?
I did this in my '72 Land Yacht, and was very happy with the change (and the silence!). On the other hand, saving $250 toward purchase of the two new AGM batteries has attraction, if the '92 Univolt is a sufficient performer to justify it's staying aboard.
Thanks for your input!
Mark
Mark Wiltrakis is offline   Reply With Quote
Old 12-04-2004, 03:22 AM   #9
jordandvm's Avatar
Profile:  2005 28' International CCD
1977 Argosy 22
Western , Oregon
Images: 58
Factory Battery
My 2004 22' CCD has only one battery....a factory installed battery! I've heard on these forums they are whimpy Since I purchased a Honda 3000 EU generator, I didn't want to invest in a new battery immediately. I'm less concerned, now that I can recharge while boondocking (and hookup when available). I plan on traveling to some extent all year (boondocking less during the winter months). My concern is during the longer periods between trips (<30 days), do I need to keep the battery charged? Since my AS is in for service and warranty work now, I asked a dealer service tech if I would need a trickle charger. He said I could plug into shore power indefinitely and not hurt the battery....he replied that it was no problem, since the newer AS's use the automatic built in charge of the converter system for charging. The charging circuit automatically controls the current, reducing it as the battery increases in charge. Is this true?? If so, I will simply check the battery fluid levels monthly and keep it plugged into shore power indefinitely!
Another question...do I leave the battery switch in "use position" or "store position"
JIm
Jim & Cheryl
2005 28' CCD
1977 22' Argosy
2004 Chevy Avalanche 2500, 8.1L 4.10 rear axle
Prodigy brake controller/Equalizer hitch
Honda 3000 genset
WBCCI #3538
jordandvm is offline   Reply With Quote
Old 12-04-2004, 08:58 AM   #10
Retired Moderator
john hd's Avatar
madison , Wisconsin
Images: 40
Mark
mark i can say this about the magnatek converter, they are rugged units.
mine was running into a battery with a shorted cell for about 2 months with no ill effect!
john
you call them ferrets, i call them weasels.
Old 12-04-2004, 05:57 AM   #11
rseagle's Avatar
Profile:  2004 22' International CCD
Spotsylvania , Virginia
Images: 33
Hi Jim,
You surely have a model 7355 switch mode charger in your 22' CCD, as I do in mine. I leave mine plugged in to shore power all the time, occasionally topping off the water level. http://www.parallaxpower.com/
As long as you're plugged in, your battery switch will stay in the "Use position".
rseagle is offline   Reply With Quote
Old 12-04-2004, 01:37 PM   #12
Reno , Nevada
Some items to note.
1) Lifeline says their AGM's charging values are the same as wet cell batteries. If you check the specs you will see this is so as the recommended ranges, while slightly different have significant overlap. Having different charging characteristics for AGM and wet cell is a nicety and not a necessity.
2) Equalization charging is not reccommended for AGM batteries. This makes me think the normal charge wizard should not be used on AGM's as it implements an equalization charging strategy (if I understand correctly). This 'non equilize' spec has implications for other battery maintainters as well.
3) The Optima batteries have very low internal resistance (Peukert coef 1.06 vs 1.2 for most other AGM and wet cell) This means that lower current draws will yield much better usable energy from an Optima that it will for most other batteries of equivalent weight. (i.e. it competes well with other deep cycles for normal RV use)
4) Gel Cells are a completely different animal and should not be confused with AGM or wet cell lead acid batteries.
Old 12-04-2004, 01:45 PM   #13
Profile:  , Minnesota
Images: 59
Originally Posted by Leipper
Some items to note.
Did you mean much better usable energy at higher current draws?
The Peukert coefficients for the Lifeline and Optimas (both AGMs) are very close.
Old 12-04-2004, 03:18 PM   #14
Reno , Nevada
"Did you mean much better usable energy at higher current draws? "
no.
you get more energy out of a battery when you draw less current.
Look at the spec sheet for a battery that shows you the amp hour rating at differing rates. You will find that the longer rating (which means less current) has a higher amp hour rating than the higher current rating.
This is key to why putting batteries in parallel is as good as or better than serial for equivalent size, type, and weight in small battery banks.
see, for instance, http://www.absolutebattery.com/deepcycle.htm
A 225 ah (20 hour or 1200 minute rate, which is the one you usually see and hear as a measure of battery capacity) golf cart battery provides 75 amps for 115 minutes (142.5 AH) or 447 minutes at 25 amps (186.25 AH). Reducing the load by two thirds (75 to 25 amps) increases usable energy by 37% and reducing draw to last ten times the 75 amp rate brings the usable capacity up to 50% more or better.
75 amps for 115 minutes = 142.5 amp hours energy available
25 amps for 447 minutes = 186.26 ah
~11 amps for 1200 minutes = 225 ah
You can also see the calculation for a 2:1 current reduction at
http://sierranevadaairstreams.org/ow...ry-config.html
One way to visualize this is to realize that any battery has an internal resistance. This is why it gets hot if discharging (or charging) at high currents. The power loss (rate of energy use) for battery heating is related to the square of the current times the internal resistance of the battery. So reducing current reduces power by the square of the current change. This is probably why the Peukert law is an exponential.
do check my calcs! I try but sometimes I see numbers backwards or do other stupid things so I need a good proofreader ;-)
If you need help (or to add to an existing confusion) about power, energy, voltage, current, etc. see
http://sierranevadaairstreams.org/ow...ng/energy.html
and
http://sierranevadaairstreams.org/ow...ectricity.html
"The Peukert coefficients for the Lifeline and Optimas (both AGMs) are very close."
1.06 versus 1.2 makes a big difference when it is an exponent!
Chassis/House Battery Charging 4 Motorhomes Jim Tyrney Airstream Motorhome Forums 40 02-15-2008 10:45 AM
Univolt boiling battery! On for 12 hours!!! Bryanhu Electrical - Systems, Generators, Batteries & Solar 8 04-10-2004 06:03 AM
Univolt Battery Boil muddy_hollow Electrical - Systems, Generators, Batteries & Solar 18 04-05-2004 10:45 PM
Univolt reminder ** Battery Check! Sav'h Steve Batteries, Univolts, Converters & Inverters 21 10-07-2003 03:18 PM
Univolt with Battery Minder COArgosy78 Electrical - Systems, Generators, Batteries & Solar 32 03-10-2003 08:59 PM
