Old 06-08-2012, 11:05 PM   #1
LiLNomad's Avatar
2007 25' International CCD FB
Northridge , California
Battery Charging STORE VS. USE
Hi have a new to me 2007 Intl CCD purchased private party so didnt have the dealer tutorial...lots to learn. I have the trailer plugged in at home. Do I need to push the "Store" or "Use" button to charge the batteries? or does it automatically charge since its plugged in?
LilNomad
LiLNomad is offline   Reply With Quote
Old 06-08-2012, 11:15 PM   #2
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
leave it on USE. Put it on STORE when you winterize it and store it for the season.
Paula
Old 06-08-2012, 11:30 PM   #3
LiLNomad's Avatar
Thanks!! Now gotta go out in my pajamas and change it hehe.
LilNomad
Old 06-08-2012, 11:39 PM   #4
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, Note: that the store function is by-passed, [red light on] and you cannot turn it off, while plugged into shore power. But it will return to whatever position it was in, [off/on] after you disconnect your shore power cord.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 06-08-2012, 11:42 PM   #5
LiLNomad's Avatar
So it IS CHARGING in either position (while plugged in) is that correct?
Old 06-09-2012, 12:17 AM   #6
Salem , Oregon
Images: 18
Hi, Yes, it is charging when it is plugged in.
2005 Safari 25-B
Old 06-09-2012, 02:56 PM   #7
Thank you - I forgot about that! While you're plugged in, it's charging and you can't put it into "store". While traveling I don't think the lights will work unless you've got it "ON".
Another little note, you'll hear a fan running on the converter and it will put out heat even with the AC on. About once a month you should turn the converter off, and vacuum out the fan. It won't run constantly unless the filter is starting to get plugged. Mine is under the bed, so I just lift the bed and the fan is visible from the top. Quick little wand job and I'm done.
OH - RESETTING the breakers, you can pop a breaker and it looks like it's OFF, then it won't reset. It's not off, it's OPEN. Push down on the breaker and it will turn all the way OFF, then pull up and turn it back ON. There are also fuses on the converter. Buy spares. They never fail until you're boondocking 50 miles from nowhere and it's 3:00 AM.
Happy Trails, Paula
Old 07-14-2012, 11:58 PM   #8
Urbanologist's Avatar
2009 34' Panamerica
2008 22' Safari
Metro Detroit Area & Metro Dallas Area , Michigan & Texas
Happy Trails, Paula
Thanks for your input on this thread! I'm puzzelled by my converter continually tripping the 20 Amp breaker when I run the AC? AC running for 5 to 8 minutes, then pop -- shut down! over and over. It's the only breaker that does this. I'll check the fan filter to see if its clean.
Urbanologist is offline   Reply With Quote
House Battery charging question dgmelp General Motorhome Topics 7 01-12-2012 08:05 PM
Battery Charging While Camping 63Sfri Batteries, Univolts, Converters & Inverters 20 09-09-2011 07:30 AM
Only one battery charging heslinhotel Batteries, Univolts, Converters & Inverters 11 02-21-2011 08:49 PM
looking for info on solar battery charging Globie64 Generators & Solar Power 11 02-21-2011 11:03 AM
