Old 10-21-2006, 04:45 PM   #1
Airstream 65's Avatar
1965 26' Overlander
2009 27' FB International
Winnipeg , Manitoba
Battery charger in place of Univolt?
Hello,
So we got our "new" (1965 Overlander) yesterday, and when we plugged it into the house, smoke started pouring out of the bathroom closet. What we found was the univolt is long gone, and it was replaced with a battery charger (see pictures below.) We would like to be able to run off 120v or 12v. So my first question is, should we replace it with a new battery charger, a new univolt or a new converter like the Inteli-Power line. And my second question is, since the battery is shot, is there a particular brand or type that is better than another? Thanks for the replies!
ID:	27276   Click image for larger version
Airstream 65 is offline   Reply With Quote
Old 10-21-2006, 08:49 PM   #2
ibgl6's Avatar
Southport (Panama City) , Florida
Send a message via AIM to ibgl6
Hello From sunny florida I am in the process of replacing my univolt with an intelipower 9100? 60 amp. I got it on line i think it would probally be a better way than just a battery charger if you are planning on using the camper any number of times a year...
Your Friend Sam In (Southport) Panama City Florida
Air#15607 TAC FL-2
Good Sam (LifeTime Member)
ibgl6 is offline   Reply With Quote
Old 10-22-2006, 06:12 AM   #3
fastrob's Avatar
1976 25' Tradewind
. , AZ to Maine
Smoke Break
Originally Posted by Airstream 65
Hello,
I just bought the converter and plugged it in without checking the wiring.
Was that smart? It worked for me.
There are sealed batteries do not need vents, they are expensive. I like the old, rather inexpensive batteries that need venting and maybe service, like water.
How is the wiring? A short could kill your new converter, battery quickly.
Robert
fastrob is offline   Reply With Quote
Old 10-22-2006, 10:10 AM   #4
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Most battery chargers are not desligned as battery maintainers. The new generation replacements, like Intelli-power, are switching power supplies and can supply 12 V. power for accessories as well as properly maintain the charge on your battery and weigh only a fraction of the weight of the older technology.
Calculate the amount of 12v. power you are going to need, add a fudge factor, and purchase the appropriate new style unit (we have a commercial vendor or two in the forums).
For a battery you need a "deep cycle" type. What you get will depend upon the capacity you need and the room you have as well as how much you want to spend
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Best battery charger for the money? Andy R Electrical - Systems, Generators, Batteries & Solar 27 10-01-2007 07:46 PM
Univolt FACTS smily Electrical - Systems, Generators, Batteries & Solar 69 08-18-2005 11:47 PM
Extra Battery Placement JaceBeck 1999 Safari 16 10-02-2002 01:03 PM
Bad Univolt? pebblepoint Batteries, Univolts, Converters & Inverters 1 07-14-2002 10:08 PM
Battery Storage JAG Electrical - Systems, Generators, Batteries & Solar 2 07-05-2002 02:06 PM
