Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Batteries, Univolts, Converters & Inverters
Old 02-07-2006, 11:17 AM   #1
luckydc's Avatar
Profile:  Richmond , Virginia
Battery Charger
I have to put my Bambi in off-site storage for a couple months. There will be no electricity available, so I will be putting the batteries in the basement on a trickle charge.
I have read posts in the past that high light the importance of putting the batteries on a board so that they don't sit on the concrete.
I am wondering if anyone can advise me as to what I am looking for in a charger. Specific model recommendations would really be appreciated! I am battery dumb, de-dumb, dumb. The Bambi has two batteries.
Also, is there anything else I should be thinking about for short-term, off-site storage? I have a boot for the Bambi, so it ain't going. It will be a fenced off area of a reputable campground.
Thank you!
Paul
WBCCI #2468
2006 Ford F-150 Lariart 4X4
2004 19' Bambi Safari LS
luckydc is offline   Reply With Quote
Old 02-07-2006, 12:12 PM   #2
LEV ZEPPELIN
crazylev's Avatar
Profile:  2004 19' International CCD
Chicago , Illinois
Hi Paul.
I have my two interstate batteries in the basement for the winter, or until we venture out again.
I bought a charger called a Battery-Minder. Here is their link:
http://www.vdcelectronics.com/batteryminder_12112.htm
I have both batteries in maintenance mode with this charger, and I think you can do up to four at a time. They cost about $50.00
This last fall I also bought a set of tire protector/covers for winter storage to protect from UV.
If you get the tire covers from Camping World, then this is exactly what you need: Camping World "Adco ULTRA TYRE GARD" NUMBER 3. These are the ones they sell for tire diameter of 27" to 29"
Harm coming from batterys on concrete is apparently a myth. This coming from interstate.
We keep the shades closed to minimize damage from sunlight exposure.
Best.
Jonathan
I'm out of my mind right now, but will be returning shortly......
crazylev is offline   Reply With Quote
Old 02-07-2006, 12:13 PM   #3
1977 31' Sovereign
davidh's Avatar
Profile:  Kalispell , Montana
I would remove Batterys and and give each of them a slow charge untill both are fully charged and then store battery's untill just before you reinstall in trailer recheck charge if still fully charged reinstall if not recharge then reinstall. You can go to any auto parts store and buy a battery charger, get a small charger that has a setting switch from 2 amp to 30amp that is all you will need to maintane your batterys. allways remove charger after the battery is fully charged if you leave on battery you could boil out the acid or fire may result and never leave a charging battery unattended.
1977 31' landyacht Sovereign
davidh is offline   Reply With Quote
Old 02-07-2006, 06:14 PM   #4
luckydc's Avatar
Thank you, Jonathan! This is exactly what I needed to hear. I assume the thing is easy to hook-up. I usually have the Bambi plugged into the house, but will be moving soon so I have to store it briefly during the transition. Sure will miss not having right next to the house!
Thanks again!
Paul
WBCCI #2468
Old 02-07-2006, 07:20 PM   #5
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
A small trickle charger will be sufficient, maximum output maybe 2 amps. Also, the battery on a board is an old wive's tale. The only time you would need to do it is if the concrete floor is painted, to keep from damaging the painted floor.
(No Longer at Inland RV)
Old 02-07-2006, 07:30 PM   #6
steelbird312's Avatar
Profile:  1989 29' Excella
1956 22' Safari
Crossville , Tennessee
Images: 11
Paul,
A lot of advice, some good, some bad, however, I suggest you check a battery manufacturer website for real facts. It seems Jonathan has done some of that with his use of the battery minder. The battery maintainers are the best thing that EVER came on the scene, just a slight bit more expensive than a trickle charger, but oh, so much better. The board thing really is a myth. Fill to proper level, keep them CLEAN, out of freezing temps, and hook a maintainer to them using jumpers, sit back and watch Nascar!
The best thing, however, is to get in it and go!
steelbird312
2000 390 Landyacht XL
1989 29' Excella
WBCCI #6673 jerry Hodge
Have no intention of arriving at the grave safely, but rather to skid in sideways, chocolate in one hand,throttle in the other, totally worn out and screaming
"WOO HOO, WHAT A RIDE!"
steelbird312 is offline   Reply With Quote
Old 02-07-2006, 07:33 PM   #7
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
I have both the 1 amp and 4 amp BatteryMinders. They both work great. I bought both through www.batterymart.com While my current trailer has an Intellipower converter with Charge Wizzard which really negates the use of the BatteryMinders, I like the units so much that I have been using them on my vehicles.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 02-07-2006, 07:40 PM   #8
luckydc's Avatar
Thanks all! I think the batteyminder is the ticket. Will I be able to hook-up both batteries with what comes with it or will I need to purchase additional hook-up wires thingies?
Paul
WBCCI #2468
Old 02-07-2006, 08:35 PM   #9
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
luckydc,
That is an 'Old Wives Tale' (sorry girls....). There is absolutely no truth that batteries act any differently when placed on a concrete floor! Put them where you want....just be sure you use a quality 3 stage charger to maintain them and check the electrolyte level every 2 weeks.
Lew Farber -Certified Master RV Tech (currently on Forums sabbatical)
WBCCI #1032/VAC (assoc) #1032 AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 02-07-2006, 08:45 PM   #10
LEV ZEPPELIN
crazylev's Avatar
Chicago , Illinois
Paul.
To keep both batteries maintaining simultaniously, use the short jumper cables that are attached to your bats. one is a red cable and the other black, both about 8"long.
Also carefully pry off the caps to check the water level before charging, and if necessary add distilled water. Others know much more about this part than me.
If you are just storing batteries for a few weeks or month, maybe you don't have to do anything. Check the voltage of each battery after it has been "resting" for 8 hours or so. Mine after a "rest" read about 12.6 volts.
I think this is good, but there are experts waiting for me to to see how my foot tastes!
Cheers.
Jonathan
Old 02-07-2006, 09:04 PM   #11
davidz71's Avatar
If your 2 batteries are wired together already in your trailer, just hook up the ring terminals (on the connector provided with the kit) to one battery and the BatteryMinder charges both. I never had a single problem with my 2 Delco Voyager batteries this way. Both charged equally.
Craig
AIR #0078
3.73 rear end
Best battery charger for the money? Andy R Electrical - Systems, Generators, Batteries & Solar 27 10-01-2007 08:46 PM
battery charger ALANSD Batteries, Univolts, Converters & Inverters 8 09-16-2007 06:52 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 03:58 PM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 02:51 PM
Battery drained while on shore power 68International Electrical - Systems, Generators, Batteries & Solar 4 07-15-2002 03:51 PM
