Old 04-27-2013, 06:09 PM   #15
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Wild Rose,
I just replaced all 4 terminals with eyelets. My cables are a #6 so I found #6 crimp eyelet ends, they can be insulated or w/o but the ones I found at hardware store on had a 1/4" hole, battery is 5/16". Got my drill and took care of that issue. I have a pair of Klein lineman pilers that will crimp the connection if you use it w/o insulation. Then I used heat shrink tubing and maintained the terminal covers for safety. The disconnects are also available thru Grainger, they are the small version of what is commonly used on lift truck battery connections, select by wire size and I think crimping required. I've considered them also. The square lug I think is a lug used in house wiring.
Good luck,
Gary
ID:	184355   Click image for larger version
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 04-27-2013, 08:59 PM   #16
Wise Elder
Jammer's Avatar
2010 30' Classic
If all you need is a new terminal, you can get a high-quality solder pot terminal from any good auto parts place or Del City or any number of other places. They have solder slugs you put in the pot on the terminal, heat with a torch, and push the wire into the pot. I've found them to be extremely reliable.
Short Battery Life 1Bombshell Batteries, Univolts, Converters & Inverters 32 09-16-2008 10:06 PM
Battery cable gauge Robin Stone Batteries, Univolts, Converters & Inverters 5 03-04-2008 07:52 PM
The Short, Short Trailer - Spamboree flamingo-kid1 On The Road... 2 04-14-2005 01:41 PM
12 v short Don McKelvay Electrical - Systems, Generators, Batteries & Solar 8 10-25-2003 11:44 PM
