Old 06-03-2016, 03:14 PM   #15
youngpeck's Avatar
1976 25' Caravanner
Salt Lake City , Utah
Any suggestions on any type/style/brand of battery disconnect switch?
youngpeck is offline   Reply With Quote
Old 06-03-2016, 03:15 PM   #16
lewster's Avatar
Naples, FL , Hood River, OR
Blue Sea Systems M-Series
Lew Farber
ABYC Certified Master Marine Electrician
AM Solar Certified Installation Center*AMS Lithium Batteries
Lifeline AGM Batteries**Magnum Inverters***Victron Energy Components
541-490-6357
lewster is online now   Reply With Quote
Old 06-03-2016, 03:34 PM   #17
youngpeck's Avatar
1976 25' Caravanner
Thanks much!
Old 06-04-2016, 09:36 AM   #18
Cloudland2
davidrrand's Avatar
2016 25' Flying Cloud
Trenton , Georgia
Thanks Lew! Do you make house calls? LOL I imagine you are already back in Oregon. Until I can get a pro to rewire the batteries per your suggestion, can I just disconnect one of the negative cables or do I need to disconnect both?
Dave
davidrrand is offline   Reply With Quote
Old 06-04-2016, 11:10 AM   #19
lewster's Avatar
Dave
If you have the stock battery arrangement of 2 group 24s in parallel, simply remove the both small cables that connect the two batteries. That will effectively break the circuit without having to also remove the automotive type connectors.
Lew Farber
541-490-6357
Old 06-05-2016, 12:58 PM   #20
Cloudland2
davidrrand's Avatar
Trenton , Georgia
Lew Farber
541-490-6357
Thanks! Yes sir, the two stock 24s. So I disconnect the small black negative parallel cable, then the small red parallel cable and all is disconnected?
Dave
Sorry to be so dim.
Old 06-05-2016, 04:12 PM   #21
lewster's Avatar
Should do it.
Lew Farber
541-490-6357
Old 09-01-2016, 05:41 PM   #22
greghoro's Avatar
2013 25' Flying Cloud
Wheaton , Illinois
And BTW, I'm no fan of the automotive type battery clamps that Airstream uses in every trailer they build. Proper deep cycle systems always use solid copper eyelets that can be attached to the battery with either a nut or bolt, tightened to the battery manufacturer's recommended torque.
Any suggestions on any type/style/brand of solid copper eyelets to replace the automotive type battery clamps?
Greg
greghoro is offline   Reply With Quote
Old 09-01-2016, 07:49 PM   #23
2016 28' International
San Marcos , California
[QUOTE=lewster;1801038]
Originally Posted by Papa smurf View Post
To your question; a single connection on each battery as described above will assure you of using all of the battery cells equally during discharge. This will give your battery cells an equal 'workout' during any discharge event and also allows for a single cable connection to a disconnect switch for complete battery isolation.
The Interstate SRM-24 batteries only have a single electrical connection, although they do have 2 ways to attach loads to that connection one threaded and one standard terminal post.
I don't think there is anyway you can wire up a 12V lead acid battery so that the load doesn't travel through all of the cells equally.
Am I missing something?
Mgieselman is offline   Reply With Quote
Old 09-01-2016, 08:16 PM   #24
lewster's Avatar
[QUOTE=Mgieselman;1844612]
Absolutely!
In any 2 battery system, the loads should be split across both batteries in the following fashion: Positive to battery #1 and negative to battery #2.
Regardless of the size of the parallel connection cables, you should not connect both load cables to a single battery.
This is not the case in a series connection between 2 batteries, as the only terminals remaining would be the positive on battery 1 and negative on battery 2.
Old 09-02-2016, 01:27 PM   #25
[QUOTE=lewster;1844620]
Originally Posted by Mgieselman View Post
Absolutely!
That applies to 2 batteries connected in series but not to parallel, if you connect them in parallel it doesn't matter were you connect the load or even if you do it in multiple places as Airstream does.
When a load is applied to batteries connected in parallel it draws equally from all the batteries in the bank. This can be proven out using a DC current clamp around the connection to each battery.
Here's how my batteries were connected from the factory.
Old 09-02-2016, 02:31 PM   #26
1977 31' Sovereign
none , none
Not quite. Recommended practice is to wire like fig.1. The reason for this is that the wire connecting the batteries together has a small resistance that will create an imbalance between the batteries charge / drain in a parallel configuration. If you have more than two batteries in parallel as I do it is even more important to wire as in fig. 1 .
There's only one way to wire in series configuration...
lightmind is offline   Reply With Quote
Old 09-02-2016, 03:01 PM   #27
lewster's Avatar
[QUOTE=Mgieselman;1844935]
Your batteries are wired EXACTLY as I recommended! The inverter cables are split between both batteries as are the house DC cables.
Neither are connected to a single battery but are spread across both.
In addition, those 6 AWG parallel cables should be significantly larger, as they should be fully compatible with the much larger internal connectivity bus found INSIDE the batteries that physically join the cells.
Connecting both load cables to a single battery in a parallel system will almost guarantee uneven battery draw and charging.
Lew Farber
Old 12-22-2016, 12:42 PM   #28
DaveP's Avatar
2004 28' Classic
Monument , Colorado
Hi Lew,
In the upgrade to my electrical system to a ~400 Ah battery bank, would I be better off with two GPL-4DL (lifting weight aside), three GPL-30HT or four GPL-27T. The weight and cost (per Ah) is approximately the same and they would all fit under my front sofa. I am thinking lower internal resistance in the bigger batteries is good (versus external wiring on smaller Ah batteries). I am also thinking the redundancy of the smaller batteries is good. What would be your guidance?
Thanks, Dave
DaveP
2004 Airstream Classic 28 "Willard"
2014 Ford F150 FX4 Ecoboost
DaveP is offline   Reply With Quote
Electrical Question Which Battery Cable is Positive? Tony S Electrical - Systems, Generators, Batteries & Solar 5 05-21-2016 06:33 PM
Coax Cable for Outside Cable Connection Frank&Mike Audio, Video & TV 7 12-17-2012 09:16 AM
1970 31ft sovereign international battery cable question travalota Batteries, Univolts, Converters & Inverters 1 09-27-2011 07:53 PM
Battery cable gauge Robin Stone Batteries, Univolts, Converters & Inverters 5 03-04-2008 08:52 PM
