Old 08-15-2017, 03:08 PM   #1
2014 25' FB Flying Cloud
Park City , Utah
Battery Cable Crimping Tool Help
In the middle of replacing interstate batteries with AGM's and would like to replace the standard automotive battery connector with a copper eyelet. From what I gather, mostly from reading Lewster's posts (thank you), the proper procedure is to crimp not solder.
So, I guess that means ordering the appropriate sized eyelet connector and crimping tool. Feels like the tool, if of proper quality, is a one time use tool that maybe expensive.
So, does anyone have one that I can borrow either in the Salt Lake City area or the Idaho Falls area or is there an alternative recommendation for this procedure?
I will be ordering the parallel cables from Lewster, so no need to use the tool but this once on the battery cables.
Thanks in advance for the Advice.
Ted
noleander is offline   Reply With Quote
Old 08-15-2017, 03:17 PM   #2
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Copper eyelet? Are we talking about a lug connector or something else?
The reason I ask - un-plated copper is not a real good thing inside a battery box. Connectors are plated to reduce that problem.
The tools involved are specialized but not rare. A local electrician should have what you need. You probably will have to use the connector (lug) that matches up with his tool. That's just the way this stuff works.
Old 08-15-2017, 03:21 PM   #3
Park City , Utah
Yes, a lug connector, sorry for the confusion.
Old 08-15-2017, 03:25 PM   #4
2016 28' Flying Cloud
Brandenburg , Kentucky
I purchased a hydraulic cable/lug press from Harbor Freight crimp all the cables when I installed the AM Solar system in/on my AS. Was inexpensive and worked great. It's a hand held, hand pump unit.
Tsunami-v2 is offline   Reply With Quote
Old 08-15-2017, 04:17 PM   #5
1976 31' Sovereign
Oswego , Illinois
When ordering cables from Lewster just have him crimp on as he will have every thing proper to do plus eyelets, if don't no length of cables needed simple job to measure yourself. Some auto parts store have loaner tools also, only cost is deposit returned when tool returned.
Old 08-15-2017, 05:23 PM   #6
2016 23' International
Salem , Oregon
When I made some changes I just went to the local battery store that does batteries and nothing more. They cut the cables and put the ends on while I waited.
Dave
NoResults is offline   Reply With Quote
Old 08-15-2017, 05:39 PM   #7
2007 22' International CCD
also, use plated terminals, not plain copper, and use marine-grade heat shrink with the sealant inside to keep moisture and other nastiness out of the crimp area...
KE4GNK/AE
Old 08-15-2017, 05:46 PM   #8
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Might try a local machine shop or tractor/equipment repair shop. Our local NAPA has a small machine shop in the back and they will crimp the connectors for free if you buy the cable from them.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 08-16-2017, 06:06 PM   #9
JimskyD's Avatar
2018 30' Classic
Bothell , Washington
I use lugs and cable from a marine supply store as they are rated for severe environmental conditions. I use lugs that are plated and a crimper that the store will loan me, especially if I need to do the crimping on a cable that is already captive to the trailer. Most importantly I feel that a small length of adhesive coated shrink tubing seals the whole crimp job and keeps nasty stuff from getting and corroding the joint.
Good luck
Jim and Sharon Doub
2018 Classic 30
K6TKU
Bothell, WA
WBCCI 03495
JimskyD is offline   Reply With Quote
Old 08-16-2017, 07:34 PM   #10
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Ted
What's the matter with soldering?
I do it frequently, and to my mind, It's the best way to ensure connection.
Heat shrink tube over after.
MelGoddard is offline   Reply With Quote
Old 08-16-2017, 10:15 PM   #11
As has been pointed out a whole bunch of times, solder crystallizes from vibration and the joint fails. A good gas-tight crimp is what is used on aircraft, spacecraft, and anything that has to survive vibration, like a typical Airstream trailer. As a Boeing retiree, and a still-practicing engineer, crimp is the only way to go, assuming appropriate tools and parts.
KE4GNK/AE
Old 08-16-2017, 10:28 PM   #12
youngpeck's Avatar
1976 25' Caravanner
Salt Lake City , Utah
I'll add to that. A month ago the local power company had to shorten the low-hanging power lines between two poles (about 200 feet apart) on my property. While working from elevated buckets, they cut the power, cut and then crimped the newly-shortened wires. I asked about it, and they said it's much stronger than any other connection. And, yes, those wires dance every now and then during wind storms.
I, too, bought the wire crimper at Harbor Freight. Works fine.
youngpeck is offline   Reply With Quote
Old 08-17-2017, 05:31 AM   #13
Boxite's Avatar
2008 22' Sport
I've satisfactorily-crimped large cables by using a tubing-flaring tool in a bench-vise. The eyelet can be placed in the tubing holder, the cable inserted, and the holder tightly-closed within the jaws of a bench vise.
Soldering hardens the conductor at the edge of the soldered joint and sets up a stress-riser which may eventually fail from vibration. After crimping, good quality RTV can be smeared on the joint and then heat-shrink will make a nice, clean, final to protect it.
"Tinning" is sometimes used to belay corrosion. Tinning is the use of high tin-content plating on the individual strands of a cable before the cable is wound. This is commonly done by mfr's of aircraft and marine wire/cable and is why it costs more than the common household/automotive stuff. However, soldering the cable after it's wound is not a good idea for the already mentioned reasons.
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
Old 08-17-2017, 07:43 AM   #14
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
{barge}
do you think I'd need that kind of crimper (the Harbor Freight one) to crimp a lug onto a #6 wire? Or would a typical hand crimper/pliers work?
(I ran some #6 as a solar pre-wire for possible future solar panels; had the walls open for a full monty, so I took the opportunity to put wiring in while I had the chance. )
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Battery Cable Identification Help AirGal04 Electrical - Systems, Generators, Batteries & Solar 7 03-31-2014 09:56 PM
Coax Cable for Outside Cable Connection Frank&Mike Audio, Video & TV 7 12-17-2012 08:16 AM
Battery Extraction Tool? Silver Otter Batteries, Univolts, Converters & Inverters 17 01-04-2012 07:18 AM
PEX what crimping techniques work best perryg114 Plumbing - Systems & Fixtures 24 09-28-2011 08:09 PM
pex crimping rama777 Fresh Water Systems 5 10-28-2006 04:44 PM
