Old 01-15-2012, 07:47 AM   #1
Ridgerunner3's Avatar
2002 25' Safari
Fountain Inn , South Carolina
Images: 13
Battery Box Modification Options
My 02 Safari came with a plastic battery box mounted on the tongue behind the propane tanks. The box is big enough to mount a size 31 battery. Right now there is a size 24 lead acid marine battery mounted. I am planning on updating my converter to a good three stage converter/charger and increasing my battery capacity.
The only simple option I see is going to a size 31 AGM battery like a Lifeline battery. Has anyone come up with a simple option to haul two batteries on this type of AS? The dual cam hitch mounts pen up against the present battery box which leaves no room for an additional box beside the present battery box.
Any ideas are more than welcome.
Bud
Ridgerunner3 is offline   Reply With Quote
Old 01-15-2012, 10:00 AM   #2
RichardT's Avatar
Raise the box to clear the mounts here is a picture of an old trailer with a raised box for the same reason you mention. http://www.flickr.com/photos/airstre...57628625126507
RichardT is offline   Reply With Quote
Old 01-15-2012, 11:50 AM   #3
2002 25' Safari
Images: 13
Thank you. That is a logical solution.
Bud
Old 10-09-2013, 01:43 PM   #4
1972 25' Tradewind
fort lauderdale , Florida
RichardT,
I am in search of a new battery box solution also. The link you posted above seems inaccessible. Could you post the pics or see if the link still works for you
thank you
ehodg66 is offline   Reply With Quote
Old 10-09-2013, 03:51 PM   #5
1998 19' Bambi
Parkville , Missouri
Same as EHODG66 link seems broken can you send pics
MoBambi is offline   Reply With Quote
Old 10-09-2013, 04:28 PM   #6
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
I'm interested too. Only the one box on my trailer tongue and I would like to add another battery. Picture please.
Alan
Storage Solutions: battery box and new made-to-open twin beds whitefawn All Argosy Trailers 5 12-19-2014 02:33 PM
Argosy Battery Box Gary H Batteries, Univolts, Converters & Inverters 8 01-05-2012 05:00 PM
'61 Tradewind battery box Q Cycle 1959-69 Tradewind 6 09-23-2011 11:20 AM
Volt meter on battery box Denis4x4 Batteries, Univolts, Converters & Inverters 0 07-14-2011 12:56 PM
