Old 09-25-2014, 01:22 PM   #1
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Battery Box Lid Catches Front Lower Rub Rail
Is there anyway to adjust the battery box that is mounted on the A frame or lid so the lid doesn't catch the lower rub rail. When opening my battery box lid I have to bend the lid a little to get it to clear the rub rail molding. I noticed the lid is riveted to the hinge. Is the battery box adjustable? This is for my 2008 Classic 25fb.
Kelvin
Old 09-25-2014, 02:20 PM   #2
2010 27' FB Classic
N/A , Texas
In my opinion,
The easiest and fastest way would be to take a grinder to the edge of the cover that is rubbing against the trim. I did that with an older AS I used to have and it worked great afterwards. I didn't even have to remove the lid. Just file or grind it while it's attached and in the open position.
Old 09-25-2014, 02:35 PM   #3
KJRitchie's Avatar
2008 25' Classic
I thought about that. Recently I purchased a portable grinding wheel to sharpen my lawn mower blade. I could use that. I only need to take off about 1/8", maybe less. I hope I can grind it straight.
Kelvin
Old 09-25-2014, 02:36 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
Historically there was a utility box mounted in the A frame. I that is what you are referring to and that lid is hitting the banana strip you may have body separation of the trailer skin coming free of the c channel. If it is seperating on the outer skin it is likely separating on the inner skin. You should be able to get to the inner skin by lifting the coach or removing any cabinets that may be across the front of the trailer. If the rivets have failed it will be clear.
The picture is what I found when I removed the banana strip
2004 Excursion 4x4
Rub Rail, Rub Rail 'where art thou?' Radman Clearcoat, Exterior Paint & Trim 18 08-09-2017 08:27 PM
How do we lower the the under-the-mattress lid? Ccjohnson Airstream Trailer Forums 4 12-30-2013 10:27 PM
Lower front curtain rail location... ugh. Airslide Upholstery, Blinds, Walls & Interior Finishes 3 08-31-2008 02:44 PM
black rub rail and trim insert wb13798 Airstream Motorhome Forums 2 01-30-2003 12:10 PM
