Old 07-16-2016, 04:47 PM   #1
2015 28' International
Ofallon , Missouri
Battery Box Extension
From the threads I’ve seen on this forum, it appears quite a few of us have modified our battery boxes to accommodate larger batteries for dry camping or boondocking (or at least are thinking about it). I found some info on the forum about fitting larger batteries, but not much and not enough details to tell me how folks modified the battery box. So I decided to use my engineering background to custom design my own modification. In this thread I’m providing the details of my design including instructions and pictures of the install. I have the drawings for the extension and lid that I provided to a local sheet metal shop to fabricate the parts. I will make them available on the classified portion of this Forum – look for “Battery Box Extension Plans.” If you use my plans, check the overall size of your battery box first to ensure my design fits your box. Also, some Airstreams have a front storage door, so this raised box won’t work (there are threads of a “lowered” box on the Forum.
My AS battery box, like most I presume, is sized for two Group 24 batteries which fit with some room to spare. Group 27s however, are at best a tight fit since the front and aft flange on the battery box is bent inwards which reduces the opening by two inches total over the size of the box’s inside dimension. The Group 27 battery dimensions I found online (most around 12 ¾ long) didn’t appear to me to fit in the current battery box opening (13 1/2 inside but 11 5/8 opening). Plus there isn’t much space above the batteries. My modification does several things that accommodate both larger (like grp 27) and taller (like 6V) batteries. It removes the fwd flange and attaches the hinge differently to increase the opening by 1”; and it adds 2 ½ inches in height. In addition to accommodating taller batteries, the additional height is helpful to house a shunt and additional wiring for a battery monitor like the Trimetric (an important dry camping item that is my next project). I plan to mount the shunt to the face of one of the extension C channels – but that’s another project and thread.
PIC 1 is where I started - the standard factory battery box with Group 24s installed.
PIC 2 is the extension I designed. It is made of 3 C channels (aft, L & R) that are 2 ½ inches tall, and one flat side which is designed to mount to the fwd side of the box where the current box flange is removed. At 2 ½ inches tall, the top edge of the extension does come fairly close to the front surface of the AS – but it does fit and the lid opens with clearance. I designed the extension to be made from bent sheet metal (one or multiple pieces) or a weldment. The shop I used to fab the extension elected for a weldment, which looks very good and blends right in with the existing box. I had it made from stainless steel – I specified anything from 0.050 – 0.060 thick. Before installation, I sanded and degreased the bare metal, then primed the parts with RustOleum spray primer and painted them with RustOleum spray enamel. Use multiple thin coats to avoid pesky runs.
First I attached the extension to the battery box. To install the extension on the battery box I drilled out the rivets attaching the current lid to the box, then drilled out more rivets to separate the lid and hinge. The lid is scrap, the hinge is reused. Then I used a reciprocating saw with a metal blade to cut off the fwd battery box flange as close to the box as possible while being careful not to damage the finish on the box. Then use a file to smooth the rough edge. Cutting on my beautiful AS was the scariest part of the entire process! (PIC 3 – we’re committed now!) I pre-drilled the rivet holes in the flanges of the extension, then clamped the extension to the battery box and match drilled holes in the aft, L & R box flanges (PIC 4). The fwd piece of the extension rivets to the fwd face of the battery box. On this side of the extension I pre-drilled the rivet holes in the extension, then match drilled the holes in the battery box. I used blind rivets and installed them “wet” for corrosion resistance by first placing some enamel paint in the holes.
Next I placed the lid and hinge in place, drilled holes in the front side of the box extension to match the hinge, and riveted the hinge to the extension. I designed a new lid since it needed to be approximately 1 inch longer than the old one due to the flange on the battery box being trimmed off to give me the larger opening size I wanted. With the hinge attached to the extension (PIC 5), I aligned the lid on the box, drilled the rivet holes in the lid to match the hinge and installed the rivets. I installed these rivets wet too, although the hinge itself is not painted. The sheet metal fab shop forgot to put the lip on the aft flange, so I’m going to look for a key locking latch that will work with the thickness of the door and flange.
To finish up, I will install the latch on the new lid, touch up the paint on the extension as needed, and then sit back and admire my newly modified battery box (pic 6 and 7). Tons more room now!
I hope this helps some of you out there who have been considering this type of upgrade to your AS.
Have fun and be SAFE!
Name:	Pic1 Factory Batt  Box 2Grp24.jpg
ID:	266983   Click image for larger version
Name:	Pic2 Extension and Lid Bare.jpg
Name:	Pic3 Batt Box no Flange.jpg
ID:	266985   Click image for larger version
Name:	Pic4 Extension Install.jpg
Name:	Pic5 Hinge.jpg
ID:	266987   Click image for larger version
Name:	Pic6 Finished.jpg
Name:	Pic7 Finished  Open.jpg
mpsgolf is offline   Reply With Quote
Old 07-16-2016, 04:52 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Very pretty. I did basically the same thing but not so professional looking. I am a pretty good wood worker but metal work is a bit of a challenge.
MICHAEL
Old 07-29-2016, 09:58 AM   #3
Ofallon , Missouri
Update
If I had it to do over I don't think I would paint the extension. I don't think the enamel paint is going to be as durable as I hoped. The extension is stainless steel so it will weather well. Also the silver of the stainless would blend well with the aluminum.
Old 07-29-2016, 12:44 PM   #4
HD Pilot's Avatar
2017 23' International
Decatur , Texas
Nice work and thanks for the detailed explanation and pics! I just picked up my Airstream a few days ago but love to see what upgrades are being done to improve the Airstreams. Once I get comfortable just getting around with the Airstream I want to do some upgrades myself, love to wrench, tinker, etc.
HD Pilot is offline   Reply With Quote
Old 10-19-2016, 09:42 PM   #5
2015 25' FB International
Sequim , Washington
Battery box extension plans
Sir
Your ad for purchasing your battery box extension plan has expired. If you plan to renew it, please do so to allow the purchase of your plan. I too would like to complete this modification to allow the use of golf cart batteries.
Thanks!
slattekd is offline   Reply With Quote
Old 10-31-2016, 08:06 PM   #6
2011 28' Flying Cloud
Orillia , Ontario
Lower
Why go up and not cut out bottom to lower the batteries?
Rust is offline   Reply With Quote
Old 10-31-2016, 08:48 PM   #7
New Borockton , Alabama
Images: 21
I like it. Would think Andy is having a fit with possible frame separation but maybe not and it sure looks sexy. I broke our my welder this weekend and starting to play with battery box design ideas again.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Old 10-31-2016, 09:46 PM   #8
lewster's Avatar
Naples, FL , Hood River, OR
Nice work!
But to get group 27's to fit easily, you simply rotate then 90º in the battery box. Works like a charm every time.
I only use the risers for taller batteries like Lifeline GPL-4CT golf cart units.
Old 11-03-2016, 10:39 PM   #9
Sequim , Washington
Originally Posted by lewster View Post
Nice work!
I have been wondering if two GPL-27T batteries will insert into an unmodified 2015 battery box without modification. I figure the hold down rod and tray have to go. The Lifeline GPL-27T are 6-5/8" wide. They should fit sideways with about 1/4" to 1/2" to spare once in but..........can the second battery get through the narrowed opening once the first battery is in place? It seems like the box's top lip (bent over about an inch) and the first installed battery will impede its drop into place. With gravity working to help drop it into place, how easy will it be to extract? Your practical experience in this would be appreciated before laying out the $$$ for these expensive batteries.
Old 11-04-2016, 11:48 AM   #10
lewster's Avatar
Remove the threaded rid (it should simply unscrew from it's retaining but welded to the bottom of the box.
Drop in the first battery ( rotated 90 deg. or sideways) and slide it forward under the front lip.
Drop in the second battery and you should have room to replace the threaded rod.
That's all you need!!!!
Lew Farber
Old 11-05-2016, 02:19 PM   #11
mutcth's Avatar
2007 23' Safari SE
Central , Connecticut
Lew, is the 2015 battery box the same size as a 2007 box? I kind of remember seeing that AS enlarged the box at some point, but I don't remember when that happened.
Tom
Now: 2007 Safari SE 23' "Anne" towed by 2011 Dodge Durango "Herman"
Before: Argosy Minuet and T@B, towed by various Honda Odysseys
mutcth is offline   Reply With Quote
Old 11-05-2016, 05:37 PM   #12
lewster's Avatar
Tom
The box 'footprint' of the newer trailers is the same as the older models, but it is now about 2" taller so they will accommodate a pair of 6VDC golf cart batteries with no modification.
Old 02-14-2017, 07:50 PM   #13
New Braunfels , Texas
Lew - are you saying 2 GPL-6CTs will fit in the battery box of '16 25FB without modification? I'm assuming I'd need some 4 gauge to rewire in series?
dustent is offline   Reply With Quote
Old 02-15-2017, 06:27 AM   #14
lewster's Avatar
No....not the taller 6CTs, but the GPL-4CT Lifeline golf cart batteries WILL fit.
Also, when adding golf cart batteries that are 6VDC each, remember that the series connector is basically an extension of the internal bus in the batteries that connect the plates and should have the capacity to handle ALL of the available amperage. In the case of the GPL-4CT, that's 220 amps as lifelines can easily be discharged to 1C (one times the capacity).
I use nothing smaller than 2/0 weld for this application, and 4/0 0for the larger 6CTs.
I have 3 boxes of assorted parts from my airstream 59 Tradewind, I would like to sell by the box for 300.00 per box or best offer per box betsy Airstream Classifieds 0 09-19-2014 11:01 AM
Battery box and battery location(s) ehodg66 Batteries, Univolts, Converters & Inverters 4 04-22-2014 07:39 PM
Cracker box after cracker box. rebel beck Our Community 15 06-07-2006 07:53 PM
locks for battery box and propane box Chilao Doors & Locks 11 11-02-2004 06:56 PM
