Old 05-05-2007, 08:03 AM   #1
erock53's Avatar
1978 31' Sovereign
Cincinnati , Ohio
Battery and converter boxes?
I just gutted the front of my 78' and had a few questions about the battery box and the converter box. Both are plastic. My unit only came with one battery and one access door for that battery. I think that I want 2 batteries and I may just gut the current plastic box and build one inside that can hold 2 batteries. I have and idea in which I could uses 2 drawer slides so that I could access both batteries from the one access door. I am using just normal deep cycle batteries and I know that they need to be vented to the outside, but I'm not sure why they need venting? I also want to know if I could just make one big box that I could put both batteries and the converter in the same box? What type of gas are these batteries discharging? Should the converter be in a different box? Does the converter need to be vented to the outside and why? I had an old univolt that went caput and I just purchased a Paramode converter with the TempAssure. Any help would be appreciated.
erock53 is offline   Reply With Quote
Old 05-05-2007, 08:22 AM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I would only put the two batteries in a vented box. One gas that come from charging the batteries is hydrogen, remember the Hindenberg? You would not want anything that could cause a spark to be in with the batteries. The converter does not need to be in a box.
Richard
azflycaster is online now   Reply With Quote
Old 05-05-2007, 10:43 AM   #3
SmokelessJoe's Avatar
1976 Argosy 24
now being enjoyed by Heath and Mary in , Vermont
eRock:
This almost current thread will contain information useful for your planning.
http://www.airforums.com/forums/f449...2-a-31854.html
Be careful not to have batteries gassing near electrical apparatus.
Sergei
SmokelessJoe is offline   Reply With Quote
Battery problem or converter problem Paul Daugherty Airstream Motorhome Forums 31 07-01-2003 06:16 PM
Why use a converter? PatCrusse Electrical - Systems, Generators, Batteries & Solar 2 11-27-2002 06:52 AM
Battery drained while on shore power 68International Electrical - Systems, Generators, Batteries & Solar 4 07-15-2002 02:51 PM
61 Bambi Battery 61BambiCanada Electrical - Systems, Generators, Batteries & Solar 0 05-21-2002 10:53 PM
Converter box for into floor mount FrankR Electrical - Systems, Generators, Batteries & Solar 0 03-15-2002 09:49 PM
