Old 07-10-2009, 02:44 PM   #1
rookie
1976 31' Excella 500
castaic , California
battery
Can anyone tell me what size deep cycle battery i should buy for my 76 excella 500? the battery had been stolen in storage before i bought the thing.
robotwinkie is offline   Reply With Quote
Old 07-10-2009, 02:56 PM   #2
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
There are two sizes, I sure someone will tell you which one, or you could measure the space and get the right size or sizes..
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 07-10-2009, 02:57 PM   #3
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
How many does it have?? Our Overlander has 2, the PO let them go dead and they froze and busted. I replace what was there. Group 27's Deep cycle from AUTO ZONE. Heavy about 50 pounds of lead each. I had them in there about a yr only added distilled water once. I still have the Univolt. What size should You buy? Measure the boxes and see what size it will take.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 07-10-2009, 03:04 PM   #4
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
The most amp hr. battery that will fit.Dave
easyride is offline   Reply With Quote
Old 07-10-2009, 03:24 PM   #5
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
There are three sizes for 12v batteries: Size 24, 27 & 31. I suspect the largest size that will fit in your compartment is a Size 27.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 07-10-2009, 03:42 PM   #6
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
All the posts that say whatever will fit are right, so long as you can get them out after you put them in and there should be a little space around them so they don't rub on the metal box and wear through.
Roger, if the ones you had froze and busted, what happened to the battery acid? If any of that stuff got on the box, it may be corroding. A broken battery is the gift that keeps on giving.
Gene
Best Battery? Anniedog Batteries, Univolts, Converters & Inverters 3 09-27-2007 01:01 PM
Wiring Sequence to hook up 2 x 6 volt battery pack to your 12 volt trailer battery TobyJH Batteries, Univolts, Converters & Inverters 0 05-21-2004 12:04 AM
Battery check--why don't I ever have to add battery water? Kistler Batteries, Univolts, Converters & Inverters 8 05-17-2004 09:03 PM
Battery bwj1450 1974 - 1979 Sovereign 3 04-09-2003 05:37 PM
Battery Use bwj1450 1974 - 1979 Sovereign 3 04-06-2003 07:33 PM
