Old 10-18-2013, 01:43 PM   #1
phughes's Avatar
2011 23' FB Flying Cloud
Tucson , Arizona
Battery/30 amp
When battery is in STORE position with 30 amp plugged in and the battery has been depleted, should all the 12 volt systems work
Don & Patti Hughes
Tucson, Arizona
phughes is offline   Reply With Quote
Old 10-18-2013, 02:11 PM   #2
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Yes as long as your converter is on and working properly.
Larry
lsbrodsky is offline   Reply With Quote
Old 10-18-2013, 02:19 PM   #3
dznf0g's Avatar
Oswego , Illinois
Not on all units. My converter WAS connected on the "downstream" side of the cutoff switch. I relocated the 12 volt feed from the converter to the "upstream" terminal of the cutoff switch so I could truly isolate the batts from the circuit if I needed to.
-Rich-
