Old 12-27-2013, 02:20 PM   #1
1976 29' Ambassador
San Francisco , California
Battery 1976 Ambassador 29 ft center bath
Hi everyone,
Anyone knows what replacement batterie I can install in a 1976 ambassador 29 ft center bath or the characteristics of one in place (size, amps) ?
Batterie is dead, Airstream is parked 2 hours away and we lost the paper with characteristics...
Tattone
tattone is offline   Reply With Quote
Old 12-27-2013, 04:08 PM   #2
Condoluminum's Avatar
2016 25' Flying Cloud
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
I'll offer an idea to keep thread alive, until an owner of similar vintage can weigh in...
By the 80's, Airstream designed space for what is called a "Group 27" Deep cycle battery.. They come with threaded adapter posts in addition to the large round lead posts for terminal clamps.. They are large, but high capacity.. If trailer is going to be stored remotely and left without maintainer or solar trickle charge, then expensive AGM (glass mat) batteries are not worth extra money, as they will go dead as well if left alone for months... The next smaller size is Group 24, and that may be easier to fit into the compartment.. Different models within Group 24 or 27 offer different "Amp Hour" ratings (how many amps can be delivered for how long..). Sears is selling Group 24M DieHard Deep Cycles for $89 and Group 27M's for $98. Rated at 80 and 105 Amp Hours respectively.. (Cold Cranking Amps or CCA Rating less relevant...)
Condoluminum
Condoluminum is offline   Reply With Quote
Old 12-28-2013, 12:22 PM   #3
1976 29' Ambassador
Thanks for the answer Condoluminum
After re-cabling everything inside the Airstream, and I mean everything, I am thinking about putting an AGM in there along with a 100W solar panel. Something like: 100W Solar Panels + Charge Controller RV BOAT Solar Panel KIT ALL IN 1. Have you heard of these guys?
As you said, these AGM are pretty expensive so I don't want to buy one that wouldn't fit...
Old 12-28-2013, 05:01 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
My '74 Argosy 26' has room for 1 group 24 battery.
Measure the compartment or the battery that is there. Some of the group 24 Exide batteries are a bit to tall. They fit, but it's really close quarters.
Needs love 1972 airstream ambassador 29' rear bath center twins! eBay Watch Airstreams on eBay 0 01-06-2012 01:30 PM
Dropping Holding Tanks Pans on 31 ft center Bath Excella II perryg114 Belly Pans & Banana Wraps 11 11-07-2011 12:09 PM
Should interior lights work with no battery but with Tow Vehicle connected bocotim Electrical - Systems, Generators, Batteries & Solar 12 11-03-2011 10:06 AM
1979 30' argosy airstream vintage travel trailer camper center bath floor plan eBay Watch Airstreams on eBay 0 10-31-2011 06:50 PM
