Old 09-05-2006, 09:16 AM   #1
genearnold's Avatar
1992 34' Limited
Grand Island , Nebraska
Batteries Overcharging
I have a solar charger on my trailer. I check my batteries fairly often but this last time I went a little longer and both were close to completely dry. I know I probably shortened their lives. What about setting the charge rate on the solar as well as the converter/charger? Is this something that a handyman owner can do or is it best left to a professional?
Also, on the subject of batteries in the Limited--has anyone jerry-rigged a better method to pull the batteries out of their little cubby hole? This battery box has to be one of the dumbest engineering boo-boos that Airstream made.
Gene
'92 Limited 34ft (now sold); '96 Dodge Cummins 4X2, 5speed
genearnold is offline   Reply With Quote
Old 09-05-2006, 09:26 AM   #2
Condoluminum's Avatar
1988 25' Excella
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
Gene-
There are solar power contrtollers that act to maintain a floating charge on batteries, and can be found at high end solar suppliers and West Marine, among others.. Several members here can add more details on product details and systems they've assembled that won't cook batteries..
As for battery boxes, I decided to wrap nylon rope around batteries (loop of water ski tow line..) and attach to sides of batteries with good ol' duct tape.. A screwdriver or small strip of metal under the front edge acts as a ramp, and the battery can be pulled slowly up the ramp, and then out of the box without too much straining or contact of cables with chassis.. DO shut off main power switch before pulling batteries to minimize chances of zapping power supply or fuses with shorts...
John McG
Condoluminum
Condoluminum is offline   Reply With Quote
Trailer Batteries 83Excella Electrical - Systems, Generators, Batteries & Solar 8 02-04-2013 10:57 PM
Batteries & Solar Charles Q Treichel Generators & Solar Power 2 12-02-2008 12:06 PM
Upgrading batteries Les Gilliam Electrical - Systems, Generators, Batteries & Solar 5 10-16-2002 11:58 AM
Batteries..All about batteries FrankR Batteries, Univolts, Converters & Inverters 0 07-17-2002 09:05 PM
Where should I install new batteries? Andy R Electrical - Systems, Generators, Batteries & Solar 3 03-31-2002 10:01 PM
