Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Batteries, Univolts, Converters & Inverters
Old 09-29-2009, 06:48 AM   #1
Silver Mist
LI Pets's Avatar
Profile:  1977 31' Sovereign
Riverhead , New York
Question Batteries losing charge
I have two 6V golf cart batteries that will usually last a few days with lights heat/fan and fridg/gas.
This past weekend they were drained by about 4am when we woke without heat.
So I hooked up to a friends gen and recharged in about 20-30 min.
Next night same thing.
Checked the batt connections and water all was good.
How can I find out what is drawing down the juice.
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
LI Pets is online now   Reply With Quote
Old 09-29-2009, 07:11 AM   #2
CLOUDSPLITTER
ROBERT CROSS's Avatar
Profile:  2003 25' Classic
W.N.Y. , "
Images: 52
Thumbs up
Fuse Buddy
This little gadget has been a big help finding circuit drain...
Got mine from Snap-on guy.
LOST IN THE SIXTIES
" I'll know where I am when I get there"
Bob,Sandra & "Fado"
2006 3/4 Burb 8.1
Hensley
Old 09-29-2009, 07:23 AM   #3
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 62
I doubt that a 20-30 minute charge is going to put much back into the batteries. You may not have been fully charged to start with.
Richard
Charter Member Four Corners Unit
Old 09-29-2009, 07:54 AM   #4
Lumatic's Avatar
Profile:  1971 25' Tradewind
Estancia , New Mexico
I agree with the Flycaster. If the battery is drained it will take quite a few hours to recharge the batteries with a genny.
Based on the description I suspect the furnace fan was running but the furnace stopped heating.
Pay no attention to the man behind the curtain- WoZ
Lumatic is online now   Reply With Quote
Old 09-29-2009, 07:21 PM   #5
Silver Mist
LI Pets's Avatar
I tested the power after 30 min, it showed 12.8.
The furnace was running all evening and cut out early am, I turned a light on it was barely lit.
WBCCI
Old 09-29-2009, 07:50 PM   #6
Phoenix , Arizona
Images: 62
The battery will show a higher level when you charge them. If you let them sit for 15 minutes after you stop charging, they will probably be lower.
The difference between 100% and 50% is only about 1/2 of a volt.
Richard
Old 09-29-2009, 07:57 PM   #7
Lumatic's Avatar
If you charged the battery sufficiently and it quickly looses charge suspect a bad battery. Did you wait after shutting off the converter before testing the voltage? I would test the battery voltage several times over a couple of hours with the battery disconnected. It would be normal to have a higher volt reading immediately after charging followed by a slight drop in voltage. If you test the voltage after several hours with the battery disconnected it should be just about the same. I would also take the battery, with or without the trailer, to a garage or autoparts store to do a load test. Also test the specific battery on all the battery cells. They should be close to the same voltage. One cell with a significantly lower voltage means the battery is bad.
Flycaster posted while I was writing mine. Looks like he is reading my mind again.
Old 09-29-2009, 09:24 PM   #8
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula , Montana
Let them sit for a while before checking after charging. They will "settle down". You may only have 12.6 or less. If batteries went completely flat, they may be toast. The plates and chemistry are changed.
Michelle
Sarah and Snowball
Ruby, (05 BMW R1200RT)
Daisy, (06 Diesel F-250 w/Tow Command)
Butter Cup, (06 Clssc 31 w/dinette, solar) 60,000 miles in 2.7 years.
http://Michelles-Adventures.US
http://frontyard.home.dyndns.org:8181
http://backyard.home.dyndns.org:8282
Old 09-29-2009, 08:14 PM   #9
Alwhisman's Avatar
Profile:  1978 Argosy Minuet 7.3 Metre
Dayton , Texas
Images: 57
Send a message via Yahoo to Alwhisman
How old are the batteries? (or did I miss that! lol)
When my battery goes, I'm going to set up three 21ah SLA's in parallel to increase my amp hours. I take care of equipment for the high school band and set their power supply (to run inverter) up that way and it works great. I like the longevity
Alwhisman is offline   Reply With Quote
Old 09-29-2009, 08:41 PM   #10
Silver Mist
LI Pets's Avatar
Almost 3 years old
WBCCI
Old 09-29-2009, 10:34 PM   #11
Alwhisman's Avatar
Dayton , Texas
Images: 57
Lots of good info here. 3 yrs old you should be okay. How many times they have been cycled, and possibly overcharged can shorten their life.....
.....just a basic thing, check and make sure your connections are nice and clean
Al
Old 09-30-2009, 02:05 AM   #12
Silver Mist
LI Pets's Avatar
My univolt is long gone I use this
The WF-8955 model provides 55 amps and a clean, constant 13.6 Vdc nominal output, for reliable operation of electronics and appliances. Automatic three-stage charging extends the life of your battery with output voltage modes of 13.2 Vdc “float” mode, 13.6 Vdc “absorption” mode, and a 14.4 Vdc “bulk” charge mode. The 8900 Series also maintains peace and quiet, as the cooling fan runs only when needed.
WBCCI
Old 10-02-2009, 11:11 AM   #13
CLOUDSPLITTER
W.N.Y. , "
Images: 52
Wink Should I replace this battery
It won't hold a charge.....
LOST IN THE SIXTIES
Bob,Sandra & "Fado"
2006 3/4 Burb 8.1
Hensley
Old 10-02-2009, 11:44 AM   #14
richinny's Avatar
Profile:  1994 34' Limited
Westchester Cty. NY , & Miami FL
i'm going to put a c clamp in my emergency box right now. i hate to tie up the vice grips on the battery all the time.
if that slide bar was just a bit longer you could do a load test on the battery.
Ricky
Ingrid - my unofficial '"World's Oldest Airstreamer"
January 1909 - October 2008 R.I.P.
richinny is online now   Reply With Quote
Honda gen to charge batteries Roamin' Cat Generators & Solar Power 7 05-30-2008 10:29 AM
How to charge the batteries from the TV jlester Batteries, Univolts, Converters & Inverters 7 04-12-2008 10:53 AM
Required voltage to charge batteries CrawfordGene Batteries, Univolts, Converters & Inverters 13 11-24-2007 09:33 PM
New Batteries Won't hold charge Relentless Batteries, Univolts, Converters & Inverters 9 05-01-2007 10:43 PM
batteries wont hold charge Lido&Linda Airstream Motorhome Forums 13 10-26-2003 03:08 PM
