Old 12-14-2008, 11:34 AM   #1
Batteries Left in Camper in winter
I park my Airstream in lower Delaware in the winter. I plan to install charged batteries in the trailer at the end of December. Will they discharge by the middle of January? There is no electrical hookup where the camper is stored. Thanks, LCP
1992 25' Airstream Classic/Excella Trailer
Wilmington, DE
PARKS1963 is offline   Reply With Quote
Old 12-14-2008, 11:48 AM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
This shouldn't be a big problem - http://www.airforums.com/forums/f449...tml#post644132. Also scroll up to the voltage chart posted by nickcrowhurst.
You'll be towing or taking it to somewhere with an electric hookup then?
Please use our standard size 2 font, no bold. Thanks!
5 meter Langford Nahanni
Old 12-14-2008, 11:54 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Battery discharge is a function of time and temperature. If you are only leaving the trailer for a couple of months, and they were fully charged, it will most likely be OK. If how ever you are talking 3 or 4 months, and they are the colder months, then I would suggest removing the batteries and getting them inside.
If you are leaving them make sure to turn off the battery kill switch as the gas detector, tv amp., and the converters with a battery minder may still be on and drawing small amounts of current that will take it's toll.
2004 Excursion 4x4
Old 12-15-2008, 11:43 PM   #4
New Borockton , Alabama
Images: 21
I too think you will probably be Ok for just a couple of weeks but why not store them in a garage or somewhere they can stay warm until you use them? Cold batteries self discharge faster.
Also, if you are buying new batteries, they should be charged but don't assume that. Make sure they are fully charged or don't buy them. If they set on the dealer shelf for a few months, they need charged.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Old 12-16-2008, 04:04 AM   #5
rseagle's Avatar
2004 22' International CCD
Spotsylvania , Virginia
Images: 33
Solar Battery Charger/Desulphator
I'd recommend one of these!
12 V 2 Watt Solar Desulphator | BatteryStuff.com
or
http://www.batterystuff.com/solar-chargers/SP-5.html
"THE BAUXITE BUNGALOW"
2004 22' CCD
1997 F-150
TAC VA-12
AIR# 4749
ex WBCCI# 1430
rseagle is offline   Reply With Quote
Old 12-16-2008, 06:34 AM   #6
bertro's Avatar
1971 23' Safari
Groveport , Ohio
I also am planning on leaving my lifeline battery in this winter as I go in and pittle around here and there. I have electric to plug in to keep a full charge but will the extended freezing temps hurt it. Thanks Robert
bertro is offline   Reply With Quote
Old 12-24-2008, 05:40 PM   #7
Images: 21
Not likely to hurt the batteries if they are on a charger. Millions of car batteries will make through the winter if they are charged. Warm is better but not always practical. Keep them charged and you should be fine.
winter batteries kepko Batteries, Univolts, Converters & Inverters 18 11-10-2008 01:41 PM
Leaving batteries connected over the winter StAlphonzo Electrical - Systems, Generators, Batteries & Solar 7 10-02-2008 02:44 PM
When you are old, all you have left is philosophy. hshovic Off Topic Forum 6 02-18-2008 07:02 AM
Tie House & Coach Batteries for Winter Storage? N2XBW Electrical - Systems, Generators, Batteries & Solar 5 11-23-2007 10:29 PM
How long can my batteries be left in the coach? Kistler Electrical - Systems, Generators, Batteries & Solar 10 07-04-2005 06:47 PM
