Old 05-20-2007, 03:08 PM   #15
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Originally Posted by Alumatube
Just an FYI--as a former employee of Interstate Batteries, I can tell you that Interstate is an automotive battery distributor, not a manufacturer. Their batteries are mostly made by Johnson Controls. (They actually do manufacture some of their small batteries but not automotive batteries.)
Just FYI!
Susan
Thanks for the information. This is why I quoted my source, to make it clear that I could not confirm the information. Perhaps he meant, but didn't say, that Costco gets their batteries from Johnson Controls, as does Interstate.
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 05-20-2007, 05:09 PM   #16
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I've fallen into the bad habit of checking mine annually (I have to do better) and found that for the last two years the upper plates have been exposed. In my case I need to do this more often and the condition of mine are purely my fault.
On my Safari I was much more dilligant due to the battery box being easy to access. With the difficulty of getting to these in my Classic, I've been neglectful and will pay the price by having to replace either this year or for sure next. My saving grace is that I don't boondock and the only use that my batteries get is running the jack when I pick it up or drop it off at my storage location.
Jack
Jack Canavera
STL Mo.
AIR #56
jcanavera is online now   Reply With Quote
Old 05-20-2007, 08:47 PM   #17
lewster's Avatar
Naples, FL , Hood River, OR
Jack
Hey Jack,
You NEVER have to water an AGM, and Lifelines have a 5 YEAR WARRANTY!!!
Old 05-20-2007, 09:25 PM   #18
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by crazylev
I was just at the storage place today and after sitting for a few weeks with out any shore power, they read 12.2 volts.
Is 12.2 volts still OK?
Jonathan
Jonathan, 12.2 volts is about 25% charge remaining. When fully charged, they should be 12.65 volts or more, and a specific gravity of 1.275.
We learned when Ford specified the group 65 battery, there was not enough room in the battery for the plates and electrolyte. There were interwall separations (no cranking amps/ internal opens), and distorted plates causing shorted cells (dead cells). The solution for a time was to produce a battery with the same physical dimensions, but fewer plates, and less cranking amps. These batteries, while having less cranking amps, had more reserve capacity than the standard group 65 battery.
Old 05-20-2007, 09:38 PM   #19
jcanavera's Avatar
Fenton , Missouri
Images: 143
Originally Posted by lewster
Hey Jack,
Yes, I'll give that due consideration. The other option is maybe a Delco Voyager which while being a flooded battery, under normal operation doesn't need periodic water additions. Since I don't boondock that may be the better price performance choice.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 08-27-2012, 07:14 PM   #20
PhilipKS's Avatar
1999 34' Excella
NE Central , Kansas
Ok, everyone! Time to revive this 5 year old thread. To all of you who replaced batteries in 2007, how are they holding out? Don't be shy, tell us which you bought and why, and if you regret it, or were they perfect?
BTW, my batteries are stickered 6/2006, and they are Everstart (by Johnson Controls) Deep Cycle Marine (and fine print says trolling). I just checked out the water levels them. One was fine, I just added a bit of distilled water. The other battery was way overdue for feeding...it took almost a gallon of water. I'll take it soon and have it tested. I have no clue about voltages/amps or outputs. I have the parallax 7400 series charger/converter with 65 amp output which I believe is original equipment.
Is the parallax a good unit, or should I save some scratch to upgrade?
Thanks for your input!
Philip
AIR 57698, TAC NM-9. http://www.flickr.com/photos/philipks/
PhilipKS is offline   Reply With Quote
Old 08-27-2012, 09:49 PM   #21
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Philip
Hi, my batteries continue to last about three years. My 2007 batteries have been replaced [dated 08/10] and the ones I have now will more than likely have to be replaced within a year. Still using Costco batteries.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 08-28-2012, 05:20 AM   #22
Skater's Avatar
1995 30' Excella
Bowie , Maryland
The Optima Blue Top I installed in the B190 in 2008 was still in good shape when we sold the van last fall, over four years later. I installed a PD9260 at the same time as the battery and basically let it handle the battery automatically. I'd check the charging mode, but I never changed it after I originally installed it.
I always had at least an electrical hookup (and kept it plugged in at home most of the time, but not always). If you're using your batteries a lot more, running them down more frequently, they might last a shorter time.
My good experience with the Blue Top + PD9260 is why I went with the same setup for our trailer (albeit with three batteries, instead of just one). We've done some camping in the trailer without electrical hookups, and I'm sure we'll do more, so it'll be interesting to see how long the three batteries last.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 08-28-2012, 08:44 AM   #23
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
Same here, only I've been using Interstates. Makes no difference, they last the same 3-4 years in our truck, car, boat or trailer. We just have too much heat here. My truck battery just died at you guessed it, 4 years. So I agree with the majority here. It's nice to have a fresh battery. A friends AGM died while we were boondocking and nowhere near a place to take advantage of the replacement warrantee.
Ahab is offline   Reply With Quote
Trailer Batteries 83Excella Electrical - Systems, Generators, Batteries & Solar 8 02-04-2013 10:57 PM
Batteries & Solar Charles Q Treichel Generators & Solar Power 2 12-02-2008 12:06 PM
Upgrading batteries Les Gilliam Electrical - Systems, Generators, Batteries & Solar 5 10-16-2002 11:58 AM
Batteries..All about batteries FrankR Batteries, Univolts, Converters & Inverters 0 07-17-2002 09:05 PM
Where should I install new batteries? Andy R Electrical - Systems, Generators, Batteries & Solar 3 03-31-2002 10:01 PM
