Old 10-16-2017, 04:44 PM   #1
2018 30' Classic
New York , New York
Batteries - keeping them charged over the winter
We have winterized our 2018 Classic and have left it our seasonal campground. We have taken the two GPL-27T Lifeline batteries out of the AS and brought them home to our apartment. We are know that we have to get something to keep them charged over the winter, but we are not sure what that something should be. What type of charger? Does one charger do both at the same time? Recommendations of a brand? I looked through the posts, but saw nothing specific to this question. Hope you all have some help for us. I don't want to have to replace these!
ajwbarnard is offline   Reply With Quote
Old 10-16-2017, 05:19 PM   #2
FCStreamer's Avatar
2014 30' Flying Cloud
I recommend the Noco G7200. It can charge both of them and take into account their composition.
http://www.ourflyingcloud.com/2017/09/new-charger.html
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
FCStreamer is offline   Reply With Quote
Old 10-16-2017, 06:16 PM   #3
waninae39's Avatar
2017 22' Sport
NCR , Ontario
dewalt makes a very good and inexpensive , charger, booster and maintainer
DXAEC80CA
it can even do two batteries at the same time
ID:	297164   Click image for larger version
waninae39 is offline   Reply With Quote
Old 10-16-2017, 06:29 PM   #4
Half a Rivet Short
Carlisle , Pennsylvania
Hi
You do *not* want something designed as an automotive battery charger. They are often designed to do all sorts of nasty things to the battery, just to get a dead one back to life. That "back to life" may only last a week, but it's long enough to enough to let you buy a new one.
Get something designed only as a trickle charger. There are a lot of brands, Battery Tender is one of many. They will keep the battery "ok" but will not do anything nasty to it. They will not rejuvenate a dead battery or one that needs charging. They will just keep a good battery in good shape.
Old 10-16-2017, 07:35 PM   #5
waninae39's Avatar
2017 22' Sport
NCR , Ontario
it does trickle mode also
Old 10-16-2017, 07:42 PM   #6
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
You don't need to keep the batteries hooked up to the charger all the time. Nor do you need to charge both at once.
Lifeline AGM batteries have as one of their selling points the fact that they'll only self-discharge by about 2% per month if disconnected. So each battery would only have to be hooked up to a trickle charger for a couple of days each month, if they were close to a full charge when disconnected from the Airstream.
I assume that since they're at your apartment, you can keep an eye on them, and hook them up to the trickle charger or disconnect them as needed.
So don't get more charger than you need, especially since storage space in an apartment is limited to begin with. A small single-battery trickle charger designed for AGMs (or with a selector switch for wet-cell/AGM charging profiles) is all you need.
Cats and ultraleather Airstream upholstery don't mix!
Old 10-17-2017, 08:13 AM   #7
Half a Rivet Short
Hi
The chargers that "also do trickle" try to guess at what they should do. Should I trickle or should I nuke the battery? Like any guess, sometimes they get it wrong. You already know the answer - just trickle, don't do anything else. If that's all the charger knows how to do, it will always "get it right".
Old 10-17-2017, 08:36 AM   #8
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
If ours were fully charged,(24hrs, Vector DSC @ 2a/hr), they lasted the entire Winter stored out of the AS.
2 grp27 Lifelines.
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 10-17-2017, 09:19 AM   #9
Mike from Canmore
Mike G's Avatar
2018 27' Flying Cloud
Calgary , Alberta
I use Battery Tender- a trickle charger.
Mike G is offline   Reply With Quote
Old 10-17-2017, 09:40 AM   #10
Amsterdamer's Avatar
2015 27' Flying Cloud
Caledonia , Michigan
I use this device for my AGM batteries: BatteryMINDer Charger-Desulfator - 12 Volt, AGM Batteries, Model# 2012-AGM
I disconnect the batteries from the camper (Moroso 74103 Battery Terminal Disconnect Switch) when I use it and it fits nicely inside the battery compartment, so I leave it there all the time. I also flip the circuit breaker for the on board charger/converter.
Amsterdamer is offline   Reply With Quote
Old 10-17-2017, 09:53 AM   #11
greenflag's Avatar
2016 30' International
Quartz Hill , California
I have regular batteries
Amazon has them. I use the one that charges both.
It is a trickle charger/maintainer. So you can leave them on all winter if desired. It shuts down when batteries are fully charged
greenflag is offline   Reply With Quote
Old 10-17-2017, 12:33 PM   #12
White Bear Lake , Minnesota
First, I have to take issue with the phrase 'trickle charger.' Trickle chargers are what we used before the smart chargers came along. They produce a constant charge rate without regard to the state of charge of the battery. They are not good for batteries.
A high powered 30 amp and 80 amp charger is not at all a good idea for maintaining batteries for long term storage. As noted they are not smart enough to know what to do with any given battery. It the charger decides the battery is very low on charge it may turn on the full charge rate and cook the battery. Those chargers are good only for getting a discharged battery enough of a charge to start an engine.
Smart chargers sense the state of charge of the battery and control the output accordingly. Some will actually turn off the charge current when the battery is fully charged and restart the charge current when the battery charge drops.
A low amperage, under 8 amps, smart charger is all that is needed to keep batteries healthy over the winter.
Lyle
lyleapgmc is offline   Reply With Quote
Old 10-17-2017, 12:38 PM   #13
richw46's Avatar
Lexington , Kentucky
That's supposed to happen with the Dual Pro charger in my boat, for my trolling motor batteries. What I have learned is, if the battery doesn't reach full charge, the charger never cuts off and just boils the batteries dry. I had two of my batteries go dry when I probably could have gone another boating season with them.
So what I do now is to put the charger on a timer (heavy duty, outdoor timer). I have it set to turn on only on Friday for a half hour. Since the batteries (3) are already charged, having them on a timer ensures the charger won't boil any of them over, should they not be able to reach 100%.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 10-17-2017, 01:27 PM   #14
Mollysdad's Avatar
Why the 7200?
I was planning on ordering the 3.5 amp version just to maintain the batteries.
Keeping Batteries Charged While in Storage beachbouy Electrical - Systems, Generators, Batteries & Solar 21 04-02-2019 09:28 PM
Keeping Battery Charged (? use Charge Wizard and associated questions) sopines5 Electrical - Systems, Generators, Batteries & Solar 13 06-07-2017 07:20 AM
Keeping Batteries Charged GLovedahl Batteries, Univolts, Converters & Inverters 4 01-31-2015 12:53 PM
Keeping batteries charged Daysailer Batteries, Univolts, Converters & Inverters 28 04-19-2012 01:02 PM
