10-10-2013, 03:38 PM
1962 24' Tradewind
Saint Louis
, MO
Batteries in winter
In a month or so, I'll probably park our Tradewind for its first post-restoration winter. The trailer has two AGM batteries, and it won't have electricity available at its winter spot. I've been warned not to let AGM's go totally dead, and that they will slowly lose power even if disconnected.
As I see it, I've got three options:
1) Rig a temporary solar panel for the winner. Drawback: it'll be parked in a storage lot and susceptible to meddling / theft / wind gusts.
2) Pull out the batteries and put them in my garage on a trickle charger. Drawback: removing them will be somewhat annoying, and no impulsive weekend dry-camping until spring.
3) Just disconnect them, leave them in place, and don't worry about it.
What do other people generally do?
Thanks!
10-10-2013, 04:42 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
What we do....
......I think you can tell.
Different opinions abound.
Plug it in...if you have a modern converter you can use the trailer without the batt's.
10-10-2013, 05:19 PM
2019 27' Flying Cloud
Albuquerque
, New Mexico
Analysis of the Options
1. Will you have sun? Days are short and cloudy, snow can cover the solar panel, etc.
2. This is what I do. I have a battery maintenance and "Battery Minder" charging center in my garage. It maintains the batteries and desulfinates them. I don't find it annoying, nor does it interfere with impulse camping. If anything my camping is enhanced by batteries that are always ready to go.
3. Even if you disconnect and leave them in place they will discharge.
Hope this helps.
Ken L 2019 Flying Cloud 27FB
2020 GMC Sierra 1500 Crew Cab 6.2L Max Tow Four Corners Unit WBCCI #5783
10-10-2013, 06:19 PM
1974 Argosy 20
Kooskia
, Idaho
I have said my piece on this issue in other threads, but #3 is what I have done for 35 years of Airstreaming, with no problems. Disconnect, clean the tops, leave them in place.
My batteries have lasted from 5 to 8 years per set.
10-10-2013, 06:50 PM
Albuquerque
, New Mexico
Based on idroba's input, please allow me to revise mine. If you disconnect and leave them for the winter, your batteries "may" discharge. Mine always did when I tried that approach.
10-11-2013, 10:23 AM
Wise Elder
2010 30' Classic
South of the river
This. One of the benefits of AGMs is supposed to be that they self-discharge at a lower rate.
