Old 01-07-2012, 07:42 PM   #1
PhiDor's Avatar
2007 34' Classic S/O
The Villages , Florida
Batteries going dead
All of a sudden the batteries on my 2007 Classic have gone dead. When parked I always shut of the main power switch. A couple of weeks ago I found the batteries dead? charged them up. Today, dead again. I know the switch was off? This is in florida so the weather is not really a factor. How can I find out if there is a short somewhere or check the batteries.
Phil & Doris Drugge
[COLOR="Red"]WBCCI #4941
"Jerry and our Amazing Dream Stream"
PhiDor is offline   Reply With Quote
Old 01-07-2012, 07:44 PM   #2
dznf0g's Avatar
Oswego , Illinois
Original batteries and original converter?
-Rich-
Old 01-07-2012, 09:03 PM   #3
dscluchfc's Avatar
1984 31' Excella
Abernathy , Texas
mine did the same thing after 4 years this time...go buy some new ones.
David
TAC # TX-18
AIR # 410
http://www.flickr.com/photos/dsphotoscapes
dscluchfc is offline   Reply With Quote
Old 01-07-2012, 10:12 PM   #4
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Yep...time for new if they are OEM.
Don't scrimp, get the best you can afford. Highest Ah rating.
Have had good luck with grp27 Interstate Marine/RV deep cycle and Lifeline AGM 100ah.
Consider a converter up-grade to help extend battery life.
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 01-08-2012, 07:56 AM   #5
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
Yup, mine too.
Ahab is offline   Reply With Quote
Old 01-08-2012, 08:49 AM   #6
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
If you got four years out of the OEM batteries, you done real good.
The batteries in my 2007 lasted until mid 2011 even with the OEM converter/charger, which is supposed to be hard on batteries.
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 01-08-2012, 02:08 PM   #7
2000 25' Excella
Northern , California
If they're 4 years old, they probably are at the end of their life. You can test them with an inexpensive load tester, essentially a voltmeter and a heating element, available at Harbor Freight, auto parts stores, Amazon, etc. From my experience, Costco batteries are identical in every respect to Interstate (except price), and both were manufactured by Johnson Controls the last time I checked.
Incidentally, I once had a mystery battery drain, and finally figured out that the refrigerator light was remaining on when the door was closed. I thought the switch was defective, so I bought a new one. Didn't help. I finally figured out that there's a couple of switches at the very top of the refrigerator frame (Dometic): the "climate control heater", and the "low ambient switch". They each have their own purpose, but one of them, the climate control heater as I recall, causes the refrigerator light to remain on when the door closes. It's very easy to inadvertently move one of these switches one way or the other when wiping a rag around the door frame. I realize you said you had your coach's main switch "off", so battery age, not refrigerator switch position may be your real issue. Test the battery with a load tester, but you can also check to see if the fridge light stays on when the door is closed.
Kamiak is offline   Reply With Quote
Old 01-08-2012, 02:25 PM   #8
Cracker's Avatar
Pittsfield , Maine
Battery Life
Here in Maine if I get 3 years out of a set of trailer batteries I'm happy as heck. I generally use conventional Interstate batteries with a reasonable amp-hour rating - but nothing out of the ordinary (i.e. - "expensive".) About once every two or three weeks during the winter I plug the trailer in for 3 or 4 days and let the batteries charge. I'm on my third set of batteries since I bought the trailer in 2003 - having changed the batteries the first time just after I bought it. As a comparison, I changed the pair of batteries in my 2003 GMC diesel for the first time just last summer (8-yrs!)
Cracker
Cracker is offline   Reply With Quote
Old 01-10-2012, 12:07 PM   #9
PhiDor's Avatar
Smile thanks to everyone
Hi,
Thanks for the responses. It's not the first time my batteries went dead, but I guess I was looking for another way out. Yesterday I broke down and went to Sears. I got 2 Diehard Deep Cycle Marine/RV Batteries, series 27 and installed them. Of course everything works now and hopefully will continue.
One thing of note, the batteries that were in my trailer were not OEM and were Interstate Marine series 24 and 500 CCA. The new ones are 665 CCA, so lots of juice there. The 24's probably died an early death because of the smaller size. OEM from Airstream is series 27
Again thanks for the comments.
Phil & Doris Drugge
Old 01-10-2012, 12:31 PM   #10
Thumbs up
Originally Posted by PhiDor View Post
Hi,
Phil,
I would monitor the batts closely while plugged in to shore power. You DON'T want to overcharge them.
I found it best to charge our OEM Interstate's for 12-24hrs, shut down and check every 7-14 daze. Better safe than sorry.
The 27's should work a good bit better than those 24's, although the CCA really doesn't apply for the RV application.
PFC
RLC
Old 01-11-2012, 07:06 AM   #11
PhiDor's Avatar
Question Battery monitoring
Now, that's a good thought. The only time my batteries are charging is when I'm towing or hooked up shore power. But how can you monitor them? The convertor does its thing and so does my alternator. All I can see is that the batteries are fully charged based on the systems monitor.
Phil & Doris Drugge
Old 01-11-2012, 07:24 AM   #12
Thumbs up
Phil,
Several options out there, I lean toward the simple.
Other folks swear the Tri-metric is the best choice.
I've found that the panel monitor is the least dependable.
I have this chart taped to the converter door for reference.
PFC
RLC
Old 01-12-2012, 04:09 PM   #13
2012 23' FB International
Hollister , California
Dead batteries
I have a newish 25 International (Aug, '11) and have had 2 instances of the battery power being low enough to be unable to operate the electric jack for the receiver after non use for 3weeks. The batteries had been depleted once as my wife failed to turn off the main switch by the door.I live in mid coastal Ca. so the weather inn a factor. How long between charges should the batteries be ok on avg? Just bought a tester, to check periodically. Since the batteries are wired in series, do I have to disconnect them from each other before checking their status?
Luftnoggin is offline   Reply With Quote
Old 01-12-2012, 05:56 PM   #14
Thumbs up
If you are "load testing" with one these....
You will need to fully charge, let sit several hrs and test separately, best done out of the AS.
I usually checked our Interstate deep cycles at least once a week during the camping season. (batts removed during storage)
Parasitic draw would usually require a re-charge about every two weeks.
PFC
RLC
Motorhomes, and Charging Batteries.... Keyair General Motorhome Topics 18 10-15-2011 08:21 AM
Yikes! My Fantastic Fans Killed My Batteries Alumaholic Batteries, Univolts, Converters & Inverters 20 10-08-2011 08:33 AM
Bad Batteries? Nightwatch Electrical - Systems, Generators, Batteries & Solar 8 05-23-2011 01:58 PM
Controller wiring to bus bar or batteries? txstreamer Generators & Solar Power 4 04-26-2011 06:10 AM
Batteries lost water/electrolyte blickcd Batteries, Univolts, Converters & Inverters 13 03-28-2011 08:26 AM
