Old 01-12-2012, 09:55 PM   #15
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
Originally Posted by Luftnoggin
... Since the batteries are wired in series, do I have to disconnect them from each other before checking their status?
12V batteries are connected in parallel. Any meaningful volt or load testing requires the batteries to be disconnected from each other.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 01-26-2012, 03:38 PM   #16
Islander
kingfisher24's Avatar
2005 28' International CCD
Deer Harbor , ORCAS ISLAND WA
trying to understand more
If one has one of these volt minders as pictured...the one pictured reads 14.15....under what circumstances....
say one;s batteries are not being charged by the converter...if one has the converter out of the picture, breaker switched off that controls the converter.
plugged into shore power, no lights on, fridge on lp...and say you are gone all day...6 , 8 hours...what would one expect the volt minder to read ????
would a fluctuation from 14.15 tp 13.0 or 12.9 during this time period mean one thing or another>?????
Several options out there, I lean toward the simple.
Other folks swear the Tri-metric is the best choice.
I've found that the panel monitor is the least dependable.
I have this chart taped to the converter door for reference.
Bob[/QUOTE]
Kingfisher24
and the Four P's(Paula, Phoenix and Peabody II and Pearl)…Peabody is here…..
2013 GMC sierra denali
WBCCI 2541
4CU
kingfisher24 is offline   Reply With Quote
Old 01-26-2012, 05:56 PM   #17
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
KF24
1…The 14.15v reading was taken while a P-Lax 7455 2 stage converter was charging two fully discharged Interstate Marine/RV batteries.
2…The pictured B/M is plugged into a 12v power port which is powered only when the isolation switch is in the "use" mode. If the converter is out of the circuit it will read zero.
Plugged into S/P….If the batteries are out, mode switch in "use" it will read 13.2, the float voltage of the IOTA, batt's installed it will read charge voltage.
Un-plugged from S/P batteries installed, "use" mode, it will read battery voltage.
3…12.9 after 8 hrs is still fully charged.
With our IOTA the charge voltage rate will vary between 13.2 & 13.8v.
Now I'm cornfused so much for simple.
PFC
"Tahawus"
but I’m the Husband, so we went to Cleveland. 😂
RLC
“It’s a crooked piece of time that we live in….”
John Prine
Motorhomes, and Charging Batteries.... Keyair General Motorhome Topics 18 10-15-2011 08:21 AM
Yikes! My Fantastic Fans Killed My Batteries Alumaholic Batteries, Univolts, Converters & Inverters 20 10-08-2011 08:33 AM
Bad Batteries? Nightwatch Electrical - Systems, Generators, Batteries & Solar 8 05-23-2011 01:58 PM
Controller wiring to bus bar or batteries? txstreamer Generators & Solar Power 4 04-26-2011 06:10 AM
Batteries lost water/electrolyte blickcd Batteries, Univolts, Converters & Inverters 13 03-28-2011 08:26 AM
