Old 01-03-2015, 06:31 PM   #1
Sioux Falls , South Dakota
Batteries, chargers, inverters, and converters
We're thinking about a late 90's 34' Airstream (wide body). What sort of batteries might we find in such a coach? What sort of charger, inverter, and converter came with the coach? I fully understand that such components may well have been replaced since the coach left the factory, which is why I'd like to know what came with the coach so I can better tell what has been replaced.
David Lininger, kb0zke
TAC SD-6
AIR 54240
Heartland mpg 181 (sold)
1993 Foretravel U300 (for sale)
kb0zke is offline   Reply With Quote
Old 01-03-2015, 08:37 PM   #2
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
There are some good threads on the individual items.
Start by finding and printing a wiring schematic and enlarging the relevant runs; for purposes of reference before you have your TT.
I'd start with the service box and work outward to relevant points
I'd also look to WAYTEK as supplier of ANCOR wiring products. See where ColinH and Lewster have pics where the rats nest is cleaned up as Airstream wiring always looks like a hurried job.
List additions you expect to make. Solar or surround sound, whatever. 120v fridge, second A/C unit necessitating 50A service or a 30A workaround etc.
Diagnostic tools are second.
BestRVConverter is a recommended source. The owner is said to be good and helpful.
Your converter may be three way or not. Always easy to change and cheap. There are improvements since then. A search of Lewsters posts will help as to current state of the art.
Threads on batteries should be central. There are enough differences that major changes may apply if not understood.
Old 01-07-2015, 10:37 PM   #3
New Borockton , Alabama
Images: 21
No doubt its a Parallax. See if you can find it. Its either the 7455 deck mount or the 7355 Power center.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Batteries, Converters, and general dry camping help appreciated AirGal04 Full-Timing, Winter Living & Workamping 8 02-19-2014 03:52 PM
Questions about inverters, chargers, and generators bertheep Electrical - Systems, Generators, Batteries & Solar 16 10-09-2010 06:29 AM
On adding batteries, inverters, etc., to tow vehicle Jammer Electrical - Systems, Generators, Batteries & Solar 15 01-13-2010 03:09 PM
Batteries and converters msmst25 Batteries, Univolts, Converters & Inverters 5 05-28-2008 07:06 PM
Batteries, Chargers, Inverters and Wire Size amalgamator Batteries, Univolts, Converters & Inverters 0 03-24-2008 06:46 PM
