07-29-2015, 12:45 AM
Batteries at 8.5 After Storing 3-4 Weeks
Hello, I parked my new 25FB for 3-4 weeks and left the inverter on, battery switch was in store. Now my battery is down to 8.5 so would like to know if plugging it into my home outlet will recharge them okay. Have I damaged my batteries in anyway?
Thank you in advance.
07-29-2015, 05:40 AM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
The inverter/charger may be wired so that it bypasses the use/store switch, in which case leaving it on means you have a load on the batteries. You should store the unit with the inverter/charger off as well.
Anyway, with the batteries drained to that extent, it's probably better to remove them and bench-charge them with a good-quality multi-stage "smart" charger, because what you need is what's called a "reconditioning" charge. Expect it to take at least two days of charging— each— to recondition the batteries.
And yes, you have damaged the batteries. Your five-year batteries will probably only be four-year batteries now. But with a proper reconditioning charge the batteries should work fine from now until the end of their (shortened) life.
07-29-2015, 06:23 AM
2012 25' FB International
Trent Woods
, North Carolina
Not only is their life shortened, but they will never hold the quantity of charge that they were designed to. You can live with that if you camp with full hookups. If you camp off the grid, you may not be able to live with the reduced capacity.
Larry
07-29-2015, 11:06 AM
Thank you for your replies.
Protagonist, today is Weds and I was planning on picking her up today and plugging her into my 110 at home until I head out Friday where I will be plugged into 30a for the weekend. Do you think that's enough time to recharge her? I dont have any other way to charge the batteries at this time. Thank you
07-29-2015, 11:12 AM
From All Over
You may experience additional capacity loss by not reconditioning the batteries, but yes, that should be enough time to bring them up to full charge.
07-30-2015, 10:27 PM
Turn off the inverter?!
We have a 28' Serinity with the same battery discharge problem. Dealer never informed us to turn off the inverter. How would someone turn off the inverter?
07-30-2015, 10:36 PM
1974 Argosy 20
Kooskia
, Idaho
There is a switch on the inverter switch panel wherever it is located in your trailer. Mine is a black panel about 3" square located in the kitchen. It has a green light on it when it is on, and no light when it is off. It is a "soft" switch, that is just a place to push to turn it on and off.
08-14-2015, 04:06 PM
2015 28' Flying Cloud
2018 33' Classic
Cumming
, Georgia
Battery charge
2015 FC 28. I never leave inverter on, just propane sniffer. Have it stowed about 3 weeks and batteries are down to 12.1 volts. Is that low or average? If leaving stored for a month, should I disconnect the negative lead? I'm really a novice here.
08-14-2015, 07:08 PM
From All Over
Sounds like you need to charge them. You are right at 50% charge right now.
When your unit is stored, if you also shut off the propane at the cylinders, propane can't leak inside the trailer, so you don't need to leave anything on at all, not even the LPG detector, and disconnecting one battery terminal will limit you to just the 5% to 10% self-discharge rate.
08-15-2015, 06:05 AM
2018 33' Classic
Cumming
, Georgia
Batteries FC28
Protagonist, should I just disconnect the battery negative lead whenever I store? Will this help maintain charge? In winter I plan to remove batteries and put on a Battery Minder.
08-15-2015, 06:15 AM
From All Over
There are a lot of caveats to any answer.
If you don't have a multi-stage inverter/charger and a place to plug in shore power…
And if you don't have a solar panel that can keep up with parasitic drains…
And if you're going to store it for more than a few weeks at a time…
… then yes, disconnecting the batteries is probably better for you.
08-15-2015, 06:29 AM
2018 33' Classic
Cumming
, Georgia
Batteries
Can that be accomplished by simply disconnecting the negative lead?
08-15-2015, 06:54 AM
2008 25' Classic
Full Time
Verify the batteries are charged fully with a multimeter at the battery posts, turn the Use/Store switch to Store and disconnect the negative cable for storage. I do that anytime my AS is in storage even if I know I'm going out the next week. Takes only a few seconds to connect the cable. I even have the LP Leak Detector connection moved to the trailer side of the Use/Store relay so it doesn't draw power when in the Store position.
Kelvin
08-15-2015, 07:16 AM
With the stock single stage Paralax converter charger on my Airstream I was lucky to get two years out of a set of batteries.
They are literally battery killers particularly if your trailer is plugged in most of the time.
You need to upgrade to a multi stage converter charger. Cost is about $250 at Bestconverter.com. If you are handy and limber you can install it yourself as it is plug and play.
Even if you never boondock and always camp with hookups you need to watch your batteries. They can be hazardous if all the fluid is boiled off by overcharging.
Depending on the condition of your batteries before you got your trailer, you may or may not need new batteries. Usually they will stand a complete discharge without failure but as the previous poster says, their life will be shortened.
08-15-2015, 02:58 PM
2018 33' Classic
Cumming
, Georgia
Battery converter
Anyone familiar with this converter as replacement for single stage in my new 2015 FC 28? WFCO Ultra III 9800 (55 amp) see pic if successful uploading.
08-15-2015, 07:05 PM
2012 28' International
Olympia
WFCO is a Chinese company, and their reliability is questionable. I would look at the Progressive Dynamics or Powermax units.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
08-15-2015, 08:48 PM
Naples
Wow! Impressive! Guess you guys are 'getting it'. You sure don't need me to pile on.
I would stay with the Progressive Dynamics PD-4655 for a direct replacement to the Parallax. They are a US company and build them in Marshall, MI. Nice folks too!
The Boondocker (silly name as you won't be using a converter much if you're 'boondocking') is made in China, just like the WFCO.
lewster
08-15-2015, 08:54 PM
2018 23' International
SANTA BARBARA
, CA
Lew, are you worried about becoming obsolete on here?! Don't worry, young man, Mark and I will keep you busy!!
08-15-2015, 09:44 PM
Naples
No worries! Just glad to see that some of my 'obsessive banter' is sinking in.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
lewster
