Old 04-17-2016, 11:22 PM   #15
dames7's Avatar
2015 25' Flying Cloud
GILBERT , Arizona
Things to remember is the frig and heater when on propane, will use the battery and the Heather will run them down very fast on a cold night.
Your always fighting to keep the charge up, if you are not hook up to shore or a generator.
David & Nancy Ames
WBCCI # 9403 -- AIR # 95597
2015 FC 25' RB
2013 Chevy Tahoe LTZ
dames7 is offline   Reply With Quote
Old 04-18-2016, 07:26 AM   #16
Tn Traveler's Avatar
2006 25' Safari
Signal Mountain , Tennessee
The fact that your batteries are taking a charge is a good sign. When you get them charged to around 12.8 let them rest over night. Then check them with a load tester. That will tell you if you are just getting a surface charge or not. Good luck.
Don
'06 Safari 25 LS
'18 GMC 2500HD Duramax/Allison
TN, Greenest State in the Land of the Free
" America is not a place;it's a road." Mark Twain
Tn Traveler is offline   Reply With Quote
Old 04-18-2016, 09:05 AM   #17
silverbp's Avatar
2014 25' FB Flying Cloud
LaMarque , Texas
Name:	ImageUploadedByAirstream Forums1460991897.173765.jpg
ID:	260939. This should help.
Sent from my iPhone using Airstream Forums silver bp
silverbp is offline   Reply With Quote
Old 04-18-2016, 04:48 PM   #18
lewster's Avatar
Naples, FL , Hood River, OR
Originally Posted by silverbp View Post
Attachment 260939. This should help.
Remember that this chart is applicable to liquid cell batteries only. AGMs and lithiums are a whole different ball of wax!!!
Old 04-18-2016, 09:18 PM   #19
greenflag's Avatar
2016 30' International
Quartz Hill , California
I would take them home. Put them on as low charge with an automatic charger.
When charged take them back to storage lot. Do not hook up your negative cable. Your solar charger should keep them up to snuff after that.
greenflag is offline   Reply With Quote
Old 04-19-2016, 05:50 AM   #20
lewster's Avatar
The stock solar charger won't work if your batteries are not fully connected. Airstream uses the internal bus bars as the connection point and without the battery cables secured, no current will flow to them.
If using a free-standing solar charger like the BatteryMinder system…….no problem!
No power to the 12 volts and batteries have completely discharged. atomeve Electrical - Systems, Generators, Batteries & Solar 31 01-07-2014 07:29 PM
6 Volts Golf cart batteries marchesi Batteries, Univolts, Converters & Inverters 11 06-10-2009 04:42 PM
Campground Electric/AirC/low volts??? crazylev On The Road... 20 07-26-2005 09:46 AM
Battery health with 110 volts going full time Mark Wiltrakis Batteries, Univolts, Converters & Inverters 11 03-15-2004 09:14 PM
need to chance to 240 volts remcolent Electrical - Systems, Generators, Batteries & Solar 1 12-16-2003 06:49 AM
