Old 03-22-2017, 06:43 PM   #1
1996 34' Limited
HARRISON , Arkansas
Batteries
Bought a 96 34 airstream, now tell me if the batteries are not good do I need new ones if I use 30 amp supply.Thank you kindly
Tom mccray is offline   Reply With Quote
Old 03-22-2017, 08:04 PM   #2
Gearheart's Avatar
1973 Argosy 24
Kitchener , Ontario
Yes All of your interior lights and the water pump are 12 volt to allow off grid camping. The power supply circuit that charges the battery could be damaged if no battery is in the circuit.
Gearheart is offline   Reply With Quote
Old 03-22-2017, 08:08 PM   #3
2017 25' Flying Cloud
Gold Country , California
Welcome Tom!
Your batteries won't matter if you are plugged into shore power. Even if you travel between sites w/power, your tow vehicle should supply enough to keep the fridge cold IF the batteries aren't completely trashed.
Hopefully that helps!
Matt
NorCal Matt is offline   Reply With Quote
Old 03-22-2017, 08:13 PM   #4
I guess there are differing positions in this! I didn't see the above before posting mine...
The 12v draws (lights, pump, venues, etc.) should still be powered through the converter while on shore power. I'm not sure if NOT having batteries installed at all will damage something. I would think you'd be fine, but hopefully some others will chime in as well.
Old 03-23-2017, 08:11 PM   #5
DaveP's Avatar
2004 28' Classic
Monument , Colorado
If no batteries are installed, you will not have break-away brakes. You need these in case the trailer separates form the TV!
DaveP
2004 Airstream Classic 28 "Willard"
2023 Ram 3500 4x4
DaveP is offline   Reply With Quote
Old 03-23-2017, 09:11 PM   #6
Naples , Florida
Not only do you need them......they are required by state law for trailers in excess of a certain weight. In many states, that threshold is 3000lbs. Some are higher....some lower but you WILL require a battery if for no other purpose than to be an available power source for trailer brake activation in the event of a disconnect from the tow vehicle.
lewster
BATTERIES. 2 NEW Interstate Batteries kapt59 Airstream Classifieds 1 08-20-2018 08:13 AM
Where to move batteries inside 23d. Upgrading to AGM batteries. Eyeballs Electrical - Systems, Generators, Batteries & Solar 36 03-08-2018 07:08 PM
Trailer Batteries 83Excella Electrical - Systems, Generators, Batteries & Solar 8 02-04-2013 10:57 PM
2 batteries outside and two batteries inside timmaah Electrical - Systems, Generators, Batteries & Solar 14 08-25-2011 07:18 AM
Batteries..All about batteries FrankR Batteries, Univolts, Converters & Inverters 0 07-17-2002 09:05 PM
