Old 09-07-2010, 04:53 PM   #1
1976 27' Overlander
Stuarts Draft , Virginia
Bad PROGRESSIVE DYNAMICS INTELI POWER 45A
I bought a PROGRESSIVE DYNAMICS INTELI POWER 45W inverter a year and half ago and I believe it is going out on me, The symtons are the 12v system works fine while the AS is pluged into shore power but once the AS is unpluged from shore power the 12v system quits working. I had the RV battery checked and it is fully charged. Even the wizzard changes from solid green to blinking as the battery nears fully charge mode. Does any body know if there is a relay inside this inverter that closes and allows the 12v system to engage once the shore power is disconneted? If it is a relay for this function I belive it's toast. Any help or discussion on this matter will be greatly appreciated.
Thx,
Eddie
mountainman1 is offline   Reply With Quote
Old 09-07-2010, 05:00 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Once the shore power is dropped the converter powers off.
The battery should be connected directly to the 12 volt distribution panel and not to the converter. You should be able to diagnose the problem with a volt meter. A bad ground connection might be the problem.
Richard
azflycaster is online now   Reply With Quote
Old 09-07-2010, 05:57 PM   #3
1976 27' Overlander
Actualy the positive side of the converter apears to be connected to both the positive side of the battery and the the positive side of the 12v distribution panel. Do you think the bad ground is the grounding of the inverter or the ground on the battery? Also this might help too. Everything worked fine until yesterday when I was using my power lift to level the trailer. All fuses I can see are ok too. I did a visual on the fuses and checked them with my OHM meter.
Eddie
Old 09-07-2010, 06:01 PM   #4
2002 25' Safari
Dewey , Arizona
Images: 62
Your 12 volt panel should be setup like the picture below. The two lines from the converter connect to the back of the panel.
Richard
Old 09-08-2010, 04:38 AM   #5
1976 27' Overlander
Is it possible for the ground connection to the dist. pannel to stop working suddenly?
Old 09-08-2010, 05:54 AM   #6
1976 27' Overlander
Richard, the proper ground for the distribution panel was the problem. I just tighten the screws that hold the power panel down and the 12v system started working with the trailer unplugged from the house. Thanks so much for the assistance you contributed on this problem. This forum and all the members are a wealth of information. -Eddie
Progressive Dynamics 4045 Converter soldiermedic Batteries, Univolts, Converters & Inverters 18 07-15-2011 06:10 AM
Inteli-Power 4560? balrgn Batteries, Univolts, Converters & Inverters 21 12-27-2010 11:22 AM
New Progressive Dynamics convertor, AGM battery, and Pendant questions wacnstac Batteries, Univolts, Converters & Inverters 16 05-09-2007 09:12 PM
Inteli-Power 30/40/50/60????? 05ModPod Electrical - Systems, Generators, Batteries & Solar 1 02-05-2005 11:40 AM
Univolt +/- Inteli-Power = ? krowsea Electrical - Systems, Generators, Batteries & Solar 4 11-14-2004 10:24 AM
