Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Batteries, Univolts, Converters & Inverters
Old 08-27-2002, 11:22 PM   #1
cameomike
Profile:
Automatic electric cord reel
I have a '84 31' Limited and have streched out the electrical cable from the reel to far and it will now not retract since the spring loaded catches cannot be clicked loose by pulling on the cable sharply. What's the trick to releasing the reel to retract the cable? A pin to depress on the reel by chance?
Mike
cameomike is offline   Reply With Quote
Old 08-28-2002, 09:56 AM   #2
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Mike.
No such luck.
It appears that your reel has said bye bye. Airstream does not have parts for them.
Most owners remove the reel and stow the cable the old fashioned way.
inlandrv.com
airstreamparts.com
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
Inland RV Center, In is online now   Reply With Quote
Old 08-28-2002, 12:32 PM   #3
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
I pulled mine out all the way one time and it would not release when I pulled on the cord. I held the cord in one hand and grabbed the reel with my other hand. I then pulled the reel in the direction that it spools the cable off just enough to unlock it. Maybe you will have the same luck.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 08-28-2002, 02:49 PM   #4
1985air345
airstreammotorhomes.com
1985air345's Avatar
Profile:  Charleston , West Virginia
I'm with Craig. Turn the reel so the cord starts the wrong way until it releases. Keep a good hold of the reel because it'll want to spin like a wild animal. If that doesn't work, I have some of the original documentation for mine. I could scan it and post it if the manufacturer is the same.
Of course, it doesn't show the 'modification' I made to the hose reel with my Dremel tool!
Fred H.
No Airstream Anymore..
Fred's Airstream Archives - Motorhomes
Fred's Airstream Archives - Trailers
1985air345 is offline   Reply With Quote
Old 08-28-2002, 03:13 PM   #5
cameomike
Profile:
I'm sure there is nothing wrong with the reel since I have done this once before but have forgotten how I retracted it. I tried grabbing the reel and sharply pulling on the reel but so far no release.
I have also painted a mark on the cable as a limit for pulling it out in the future. Thanks to you for the information, I will keep trying.
Mike
Old 09-02-2002, 12:04 AM   #6
cameomike
Profile:
Smile
I did successfully free up and get the reel to retract the cable. Drilled a small hole in side of the reel, tied a small rope through the hole and wrapped the rope over the reel to sharply yank the reel. A sharp but short jerk was all it took. Released the tied rope and I was in business as the cord retracted. I painted a limit line on the cable as a guide, as to how far I could deploy the cable in the future.
Mike
How do I remove the electric reel? k5cad Airstream Motorhome Forums 6 11-26-2003 06:16 PM
Hot Power Cord GoldFever Electrical - Systems, Generators, Batteries & Solar 7 07-13-2003 05:49 PM
Electric Brake Question 68 Suburban Brakes & Brake Controllers 6 03-04-2003 08:09 PM
External Power Cord Replacement jstaad Electrical - Systems, Generators, Batteries & Solar 3 01-23-2003 06:16 AM
Phone cord Joan D'Andrea Cabinets, Counter Tops & Furnishings 0 11-02-2002 10:38 AM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
