Old 02-06-2014, 08:29 AM   #29
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
I do believe that the 40# you will save will be insignificant in the grand scheme of things.
Also, due to the decreased amperage your tongue jack will also run much slower, putting an increased drain on the single battery even if hooked to the TV.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 02-06-2014, 08:36 AM   #30
SteveH's Avatar
Common Sense , Texas
Bruce, did you mean to say "I don't believe that the 40# you will save will be insignificant in the grand scheme of things"?
If so, I agree, it's not the weight that I'm concerned with (it's actually closer to 60# for a group 27), it's the complexity. Like I said before, if they were in series, I'd not give it another thought.
Regards,
Steve
Old 02-06-2014, 09:47 AM   #31
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I see nothing wrong with 1 battery if that is really what you want. I like having 2. I sleep with a CPAP and try to keep enough charge to run it a couple of nights in an emergency. I check the fluid level once in a while. As easy to do it to 2 as to one. I still use the original converter. Batteries last 2 to 3 years. I pretty much just change them based on age and if we anticipate needing them on a summer trip.
Would 2 golf cart batteries in series be better than 2, 12 volt in parallel? Would they fit?
Old 02-06-2014, 09:58 AM   #32
SteveH's Avatar
They would fit, and have slightly more capacity. The group 27's are about 100AH, so 200AH in parallel, and the big 6 volts that I have looked at are 210AH. Of course, there may be bigger ones out there that I am unaware of.
Going to two 6 volts really doesn't gain you much in my opinion because you are still left in the situation where if anything goes wrong with one, you need to replace both, because all batteries in a bank, no matter how they are wired, should be the same age, type, and capacity.
Regards,
Steve
Old 02-06-2014, 10:54 AM   #33
Skater's Avatar
1995 30' Excella
Bowie , Maryland
This forum amuses me sometimes - we Airstreamers analyze every issue a dozen ways, to intricate detail.
SteveH - I think you missed the "in" in "insignificant" - bwoodtx is saying the 40 lbs are insignificant. I agree; we don't change our hitch settings depending on whether our propane tanks are full or empty (at least, I don't).
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 02-06-2014, 10:58 AM   #34
SteveH's Avatar
Yes, you're right, I missed it, and some of us have too much time on our hands to sit and think about this kind of stuff when we should be out traveling in our Airstreams.
If we ever get all the Doc appointments taken care of, and/or spring gets here, that will happen.
Regards,
Steve
Old 02-06-2014, 02:40 PM   #35
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Yeah, it's winter. Only a few lucky people in nicer weather are able to go camping. Most of the rest of us are stuck in the cold, so all that's left is to dream about camping and overanalyze minor changes to configurations. And get our truck fixed so it's ready to go come spring.
Storage Solutions: battery box and new made-to-open twin beds whitefawn All Argosy Trailers 5 12-19-2014 03:33 PM
Battery Box Modification Options Ridgerunner3 Batteries, Univolts, Converters & Inverters 5 10-09-2013 05:28 PM
Battery Issues aswbe Batteries, Univolts, Converters & Inverters 29 08-08-2011 08:27 PM
