Old 05-06-2010, 06:38 PM   #1
GJP
1965 17' Caravel
Wichita , Kansas
Anyone changed from this to that?
I want to change over to new 12V fuse panel (ala Vintage Trailer Supp.) on my 65 Caravel, but dont understand how the wiring for lights/outlets/switches wire into new fuse box. Anyone done this change-over?
Name:	old to new.jpg
GJP is offline   Reply With Quote
Old 05-06-2010, 07:18 PM   #2
joqin's Avatar
1965 17' Caravel
brooklyn park , Minnesota
Sorry,I don't have an answer, but I have a 65 also that I would like to change over, so I want to hang on to this thread! joe q in MN
joqin is offline   Reply With Quote
Old 05-06-2010, 08:14 PM   #3
kevinb's Avatar
1968 24' Tradewind
1959 17' Pacer
holly springs , Georgia
GJP
see thread "doin' the full monte" by member Jim and Susan post #742, a lot of info there, he also has a link to randy at best converter,who can also help.
Kevin
kevinb is offline   Reply With Quote
Old 05-06-2010, 09:01 PM   #4
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Thanks for the shout out, Kev. I just happened to log on a few minutes ago and happened to catch this thread. Here's the link directly to the the Parallax site with the wiring diagram. It loaded kinda slow for some reason: http://parallaxpower.com/Dist_Panl/FB%20Series.pdf
Let us know if you need any help decyphering that thing.
www.nesa.org
Air No. 6427
Old 05-06-2010, 10:51 PM   #5
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
I just did this changeover in my '72. It was pretty straightforward. I assume you have the old glass fuses in your Caravel. Just do a one for one swap for each circuit using an appropriately sized fuse.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 05-08-2010, 09:47 AM   #6
GJP
1965 17' Caravel
Wichita , Kansas
Thanks for the help! I went to the parallax diagram but am still not clear (dense!) The wiring coming out of the skin that goes to the lights, etc...goes thru existing fuse panel. Each wire has two legs, and I don't understand how this wires to new parallax fuse box- what leg goes where? Guess I don't get it....do the lights which have 12V bulbs, and the receptacles/switches wiring all go thru 12V fuse box?
Name:	out the skin.jpg
ID:	102007   Click image for larger version
ID:	102009   Click image for larger version
Old 05-08-2010, 11:52 AM   #7
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
I didn't have that box unit with the switches in my '72, but it still shouldn't be too hard. Looking at your pictures it looks like each circuit goes through a switch and a fuse on your old unit. You don't need the switches anymore so remove that part from the equation. Do you know which wire controls circuit? If you don't, do this. Remove one end of the wire from the fuse and see which lights and fans you lose. Each circuit in my '72 controlled one part of my trailer, i.e one circuit for bathroom, one circuit for bedroom, one circuit for kitchen, and one circuit for control panel and outside lights. Yours should be similar.
On your new fuse panel each individual circuit wires to the bottom of each fuse. The positive lead from your battery and tow vehicle wire to the positive leads on your new fuse panel. The negative leads wire to the negative bus bar on the new panel. Some folks wire the charger/converter to this fuse panel while others wire it directly to the batteries.
1958 Overlander
4CU 1st VP
Old 05-10-2010, 06:18 PM   #8
GJP
1965 17' Caravel
Wichita , Kansas
Thank you for the help-think I'm getting it!
Old 06-20-2010, 03:43 PM   #9
FL Crackers's Avatar
2012 27' FB International
Ft Myers , Florida
Well, I'm only gettin' some of it. I figured out bringing the positive lead in from the new DLS converter and conecting the five primary circuits to the fused posts on the bottom of my new Parallax fuse panel. What I'm missing is how to handle the wires coming in from the 7-way Plug Harness. In my system, the trailer lights (e.g., four circuits for turn signals, brake lights etc.) are fused in the old panel.
Per the owner's manual, A/X, B/Y, C/Z and D/AA all serve the trailer lights. F, G, H, J and K are all fused to W the positive from the Univolt. Do I need to get a seperate fuse box for the trailer lights, or can I hard-wire them since the circuits are already fused in the truck?
Also -- the old system fuses the battery connection (e.g., L - pos, M - pos, N - neg, and P - neg). I don't see this accommodation in the Parallax. Is it necessary?
Hope my questions make sense to someone here.
ID:	105254   Click image for larger version
Mike & Laurel
Ft. Myers, FL
2012 27FB Int'l Serenity
2016 RAM 2500
FL Crackers is offline   Reply With Quote
Old 06-22-2010, 05:59 AM   #10
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
The circuits for your 7-pin connector must be on a separate fuse panel since they get power from your tow vehicle. Most Airstreams I've seen have the self healing breakers to protect these towing lights. Now the 12v charge wire from your tow vehicle will go to your regular fuse panel and will wire up to one of the 12v power feeds.
1958 Overlander
4CU 1st VP
Changed my signature... reday Sprinter and B-van Forum 1 02-22-2009 10:51 AM
Name changed NVDeputy Member Introductions 3 03-08-2008 02:09 PM
Changed Domicile fr8tshaker Full-Timing 3 06-29-2007 07:51 PM
My Status Has Changed SilverCabin Member Introductions 12 11-19-2006 08:14 PM
Wonder why it changed.... Safari Tim Our Community 17 06-06-2005 05:26 PM
