04-21-2007, 06:35 AM
1979 31' Excella 500
Detroit Area
, Michigan
Anybody know how many watts an old Univolt would draw (circa 1979 31' International?)
I'm wondering because I'm replacing with a 60A Intellipower that draws 1000 Watts on the input side. Wondering how they compare.
04-21-2007, 07:16 AM
Moderator Emeritus
1972 31' Sovereign
High Springs
Probably about the same or more. The old Univolts used a ferro resonant transformer, and they generate a lot of heat, which equates to wasted energy. Intellipowers use solid state switching technology which is more efficient.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
04-21-2007, 07:17 AM
Princeton
, New Jersey
60 amps seams like a bit of over kill. What are you using at 12 volts that requires that kind of power?
2004 Excursion 4x4
04-21-2007, 04:43 PM
Detroit Area
, Michigan
I invertor is bought and paid for. Didn't want to be underpowered As an afterthought, I was worried that my requirements to power the invertor are going to be a lot more than the old one and I do boondock continously.
04-21-2007, 07:31 PM
Naples
Is that an 'inverter' or a 'converter'? Two very different animals.
lewster
04-21-2007, 07:53 PM
Detroit Area
, Michigan
Sorry meant to say convertor. So does anybody have an answer? I suppose when I pull the old one out it might be stamped somewhere with how many watts it draws. Perhaps the 60A might charge a drained battery a little faster which is good for me as this means less generator run time.
04-21-2007, 08:19 PM
The 60A charge rate is fine if you have an AGM battery. Might be OK if you have two wet cells.
I wouldn't use that high a rate if you have a gel battery.
04-22-2007, 06:21 AM
Naples
The higher amperage units will re-charge yuor batteries faster, but it's the voltage that's most important with the different types of batteries. I don't have the exact numbers off the top of my head, but a gel requires the lowest charge voltages, with wet cell in the middle and AGM needing the highest.
I would assume that most converters and battery chargers will provide a 'safe' voltage output so as not to ruin a battery with excessive charging voltage. There is a 'new breed' of charger where you select the type of battery during set-up, and this pre-determines the charging voltages used.
AGMs like to be charged at their higher recommended voltage (per Lifeline's website) in order to acieve maximum battery life.
lewster
04-22-2007, 09:38 AM
Detroit Area
, Michigan
I have a Lifeline AGM.
04-22-2007, 10:17 AM
1981 25' Excella II
Dillon
I can't recall which thread, but someone on here did a comparison of the draw from his univolt to his inteli charger before, and after. He said the univolt put out between 5-6 amps, but never less then 5. By comparison the inteli charger went down to .6 after the batteries were charged. I don't know how that would relate to the W draw, but I would think it would be less.
Charlie
04-22-2007, 06:10 PM
Naples
Me too! Two GPL-4C 6VDC golf cart batteries replaced the 2 Interstate Group 24's. I switched out the Parrallax converter that came with the trailer to a WFCO 3-stage 55 amp unit. No problems to date.......but the real test is coming up in July when I'll be full-timing in the CCD for 3+ months!
I'll keep you posted..............................
lewster
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Univolt FACTS
smily |
Electrical - Systems, Generators, Batteries & Solar |
69 |
08-18-2005 11:47 PM |
1981 Airstream Excella Univolt
dienst1 |
Airstream Motorhome Forums |
1 |
08-20-2002 09:05 AM |
Bad Univolt?
pebblepoint |
Batteries, Univolts, Converters & Inverters |
1 |
07-14-2002 10:08 PM |
univolt III wiring
McGill |
0 |
07-05-2002 08:26 PM |
Univolt Operation
melprice |
11 |
06-17-2002 04:13 PM |
