Old 06-24-2009, 03:29 PM   #1
Frank&Mike's Avatar
2016 27' Flying Cloud
Georgetown , Texas
AMPS 20? 30? 50? Which One Do I Want?
I guess this may seem like a silly question ... but I'm still trying to figure all of this out and I'm still learning. When I am making reservations for a campsite with electrical hookups, I am typically asked what electrical AMP service do I want? 20? 30? 50?
I assume that I would want 50 AMP if it is available because it would allow more electrical appliances to operate? Or this assumption incorrect?
Is there a problem with the use of a lower AMP service or is there a risk of negatively affecting any appliances with the use of a lower AMP service?
We have a 1988 32 ft. Airstream Excella that we utilize the electrical hookups on. I haven't been able to find anything in the owner's manual that discusses this subject. Thanks in advance for educating me on this subject.
Frank&Mike is offline   Reply With Quote
Old 06-24-2009, 04:15 PM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Look at the 120VAC electrical breaker box. Confirm what the largest amperage circuit breaker is and that is the maximum amount of load that can be drawn through the wiring of that box. For most trailers that is 30 Amps. If you use a 15 or 20 amp cord adapted to a higher rated service and try to pull more amps then the cord is rated then you could start a little fire.
Old 06-24-2009, 04:17 PM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I am pretty sure that the 88 still used the 30 amp service.
20 amp is little more than a household plug in.
Aaron
WBCCI #XXXX AIR #2495
Old 06-24-2009, 04:19 PM   #4
Gael79's Avatar
1970 31' Sovereign
Lombard , Illinois
If you can, take a picture of your plug and post it, that may help. The style plug will dictate the service you need.
You can think of Amperage like a water hose. The higher the number, the bigger the water hose. Our Airstream has a 30 amp plug, but I have used 20 amp service, with an adapter, but that does not allow me to use the A/C and microwave - basically just lights and battery charging.
Scott
I have a picture of my Airstream in my wallet, and I'm sitting on it...
...If that's not love, I don't know what is!
Gael79 is offline   Reply With Quote
Old 06-24-2009, 04:27 PM   #5
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
Almost always in the trailers made since the '70's at least, 30 amps is the norm. This is true for Airstreams. 50 amps is used in motor homes. You have 30 amps unless the previous owner rewired your trailer. IIRC, even 34' Classics with two A/C's have 30 amp service and can only use one of the A/C units at a time. This may have changed on the most recent models, but I don't recall it being different.
Family of Disney Fanatics
WBCCI# 4821
https://streaminacrossamerica.com/
Old 06-24-2009, 07:08 PM   #6
Frank&Mike's Avatar
Georgetown , Texas
Thank you all for your replies. It's starting to make sense to me now. I'll take some photos this weekend and post them.
Old 06-24-2009, 07:11 PM   #7
Lothlorian's Avatar
Loganville , Georgia
I put in a 45 amp which I bought on sale. I was looking for a 30 amp, but I got a better price on the 45 amp. I would not go higher then 45.
Brian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 06-24-2009, 07:35 PM   #8
Liberator
klattu's Avatar
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie , Alabama
Images: 834
One of each would be sweet
Your opinion is valued, please not your opinion of someones else's opinion.
Click To See Me Wet
1989 Airstream 345 Liberator...
1972 Argosy 24'...
1954 Feathercraft Vagabond
klattu is offline   Reply With Quote
electrical hookups
What Amps??? Sundance Electrical - Systems, Generators, Batteries & Solar 8 03-31-2015 09:32 AM
Breaking up the 30 Amps soldiermedic Electrical - Systems, Generators, Batteries & Solar 11 07-20-2007 03:53 AM
How Big AC Input Amps??? Sundance Batteries, Univolts, Converters & Inverters 9 07-19-2007 11:59 AM
How many Amps??? Sundance Batteries, Univolts, Converters & Inverters 3 07-02-2007 11:32 PM
Meter for amps davidz71 Electrical - Systems, Generators, Batteries & Solar 5 05-09-2002 10:21 AM
