05-14-2009, 07:58 PM
1982 28' Airstream 280
Buena Park
Alternator Overcharging?
I have a 1982 diesel Airstream motorhome.
The volt gauge was showing high numbers like 18 volts. So i hooked up a voltmeter directly to the batteries and it seems that the guage is off by 2 volts.
However, it is still high, but I dont know if that isnt normal. Here is what is going on.
It idles at 500 RPM.
Starter: (Off: 13; 500 RPM: 13.25; 2000 RPM: 15)
Coach: (Off: 13.63; 500 RPM: 14.2; 2000 RPM: 16)
From the alternator post on the isolator: (Off: 7.7; 500 RPM: 14.55; 2000 RPM: 17)
Is this a problem?
05-14-2009, 09:56 PM
1967 22' Safari
1960 Caravel
Edmonds
You can get numbers like that if your battery is low. How long it lasts depends on how low the battery is, how many amps your alternator puts out and the rpm of the engine. The voltage should drop off as the battery comes up to charge.
If your battery is charged and you maintain a high constant voltage reading (depending on rpm) the voltage regulator has probably gone bad. The battery itself could be bad as well. If it is the regulator and it keeps a high charge it will cook the battery over time. I'm not sure if you have an internal (in the alternator) or external (engine compartment) regulator. Hope some of this helps.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
05-15-2009, 02:39 AM
Buena Park
The batteries are fully charged. It is a 60 amp alternator with an external regulator.
05-15-2009, 04:58 AM
1976 25' Caravanner
Campton
, New Hampshire
Put a load on the batteries for 1/2 hour , interior light , to get rid of the serface charge , engine not running . A good battery will read 12.5 to 12.7v depending on temp. It looks like your voltage regulator is gone , easy fix. BTW 60 amp alternator seems small for a MH.
05-15-2009, 05:07 AM
2011 34' Classic
Westchester Cty.NY
, / Miami FL
check the ground on the regulator. run a jumper wire to it and see if the voltage drops, do the same with the alternator. check the water in the battery.
Ricky
05-15-2009, 12:03 PM
Buena Park
IS there such a thing as a "stronger" voltage regultor? I installed a new regulator yesterday because I wasnt getting any voltage from the old regulator. So those numbers I previously gave were the new numbers.
Sorry not 60 amp. 80 amp.
05-15-2009, 01:11 PM
1967 22' Safari
1960 Caravel
Edmonds
Not that I'm aware of... With voltage regulators it's eather bad or good. Good luck.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
05-15-2009, 04:44 PM
1976 25' Caravanner
Campton
, New Hampshire
It should still regulate to the correct voltage . Make sure there is a good ground to the regulator. Check to see if you crossed the wires. Good luck
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Alternator help
tebone |
Mechanics Corner - Engines, Transmission & More... |
0 |
12-04-2008 07:05 PM |
My Alternator is connected to... This?
drfw |
8 |
07-15-2008 07:10 AM |
Batteries Overcharging
genearnold |
Batteries, Univolts, Converters & Inverters |
1 |
09-05-2006 09:26 AM |
HELP with alternator
Dorothy Whittaker |
1 |
07-11-2006 12:44 PM |
Proper Alternator??
GlenCoombe |
16 |
09-22-2005 11:39 PM |
