Old 11-20-2008, 05:49 AM   #1
2005 22' International CCD
Woodland Park , Colorado
airflow for converter
in our quest to increase floorspace in our 22' international, we decided to remove the rear bench (had already removed the front bench over the summer. the dilema became what to do with the converter. after looking at several options we decided on the one pictured below. basically i simply shortened the bench base holding the converter to 8", cut off the top brackets for the bench, moved it to just aft of the wheel well and fashioned a cover using the leftover aluminum after shortening the bench base. the propane detector i moved to the opening where the wires used to come through the wheel well cover to the converter.
in all we are extremely please with the results - the trailer is now much roomier and open. as far as seating, plan to get two of the new folding recliner chairs. they are much more comfortable than the previous benches, can be moved wherever you want them, inside or out and can be folded up and put away when not needed. next step will be to cut the table into somewhat of a half moon shape, making it more comfortable to sit at.
the only question i have is how much airflow does the converter need. you can see the converter box sits a little higher than the wheel well. i originally intended to leave it open for airflow but then decided to cover it to keep objects from falling into it. is this still allowing enough airflow to keep the converter from heating up too much? there is actually a fair amount of open space behind the wheel well cover itself, and because i used the original mount for the converter there is open space beneath though to the back of the converter. appreciate any input. jk
ID:	71577   Click image for larger version
ID:	71579   Click image for larger version
JK3500 is offline   Reply With Quote
Old 11-20-2008, 06:52 AM   #2
SteveH's Avatar
Common Sense , Texas
If the box is closed tight, I wouldn't think that is enough air flow. You might attach the top with some spacers to keep it open about a half inch, and that would probably do OK.
And then, you could just try it like it is for a few hours, and see if the box gets hot.
Regards,
Steve
Old 11-21-2008, 05:36 AM   #3
good advice steve,thanks. it does have about an inch and a half open space on the bottom. think i will raise the top about a half inch as well, as you suggested.
will be hooking to power this weekend. will see how much it heats up. jk
What to do with old converter? msmst25 Batteries, Univolts, Converters & Inverters 11 06-15-2008 03:32 PM
Where's the converter? gparker Batteries, Univolts, Converters & Inverters 4 08-24-2007 03:30 AM
tv converter.. safari05-25 Audio, Video & TV 0 11-27-2006 07:10 PM
anyone ever balance the airflow on a furnace? john hd Furnaces, Heaters, Fireplaces & Air Conditioning 18 11-25-2003 12:16 PM
Why use a converter? PatCrusse Electrical - Systems, Generators, Batteries & Solar 2 11-27-2002 06:52 AM
