05-13-2015, 07:53 PM
1993 34' Excella
Estancia
, New Mexico
AGM vs LED
What will give you more bang for your buck, switching out all your incandescent bulbs to LEDs or switching the wet cell batteries to AGMs?
05-13-2015, 08:08 PM
1972 27' Overlander
Denver
, North Carolina
Led
Lucky Dave, Denver NC
05-13-2015, 08:14 PM
Biloxi
, Mississippi
Led
MICHAEL
05-13-2015, 08:27 PM
1979 23' Safari
Wayland
, New York
LED's. Similar size AGM vs wet cell will have about the same amp hour rating, but the AGM you can discharge to about 80% discharge, a flooded cell can be discharged to about 50%, based on safety of battery life for both. So a similar size battery with 100AH rating, you'll get 30% more AH. LED's are about 80% more efficient than halogen and incandescent bulbs. So those 10-20 watt halogen bulbs become 1.5-3 watt led bulbs. So you're trading off 30% extra battery capacity for 80% less draw by the lights.
This is looking at the lights only perspecrtive, it doesn't take into account extra 30% power the AGM will get you for running the fridge, furnace, or other 12v loads.
05-13-2015, 08:34 PM
Led
But I got seven years out of my Optima AGMs, and didn't have to build another vented battery compartment to place a second batt.
I don't use the trailer lights much. and I spend most of my waking hours out side. I have been using solar powered LED garden lights. Zero drain on my house batts. For me it's enough light. Use them inside and out.
05-13-2015, 10:37 PM
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach
, British Columbia
Led's
George
05-13-2015, 11:13 PM
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town
LEDs are MUCH less expensive ...
05-13-2015, 11:21 PM
1978 25' Tradewind
Metro Phoenix
If the majority of your usage is lighting, you're much better off with LEDs. If your lighting use is slight but you're running the furnace blower and a couple CPAP machines quite a bit, AGMs could conceivably be a better deal.
Or do both.
05-14-2015, 02:59 AM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
LED's then upgrade to the AGM's when the time comes.
Aaron
WBCCI #XXXX AIR #2495
05-14-2015, 06:00 AM
2016 28' Flying Cloud
Brandenburg
, Kentucky
LED, but AGM is maintenance free, to a large degree and as has been stated before, ability to deep cycle the AGM.
05-14-2015, 06:25 AM
1988 Argosy 32
Lomita
LED's are low cost and Quick to put in and cut demand on the system.
Before AMG install a 4 stage charge controler is a must if the AMG's are to last.
Best is a Pure sine wave Inverter charger that output's 120 Volts AC.
then add 200-400 Wats of Solar to finish system mine has run 4+ years.
The best webb sight is A&M solar, read all of it before you start.
05-14-2015, 06:59 AM
2015 30' Classic
2012 28' International
Greensboro
, North Carolina
I opted to do ALL OF IT at one time with my new Classic. All of the OE lighting is LED (except for the Baraldi range hood -- for which I have already replaced the halogen bulbs). I added the Magnum MSH inverter...which has a highly sophisticated inverter/charger set-up, as well as a 600W AM Solar package. 4 Lifeline 6V AGM batteries which are INSIDE the trailer. Granted, a fair expense, but no trade-offs for off the grid trailering. Also, no worries about battery overcharging with a high-quality system. For dire straits or A/C, I have a Honda EU3000i Handi.
_________________
"SilverLeaf II" 2015 30' Classic
2019 RAM 2500 Limited 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
05-14-2015, 07:10 AM
2010 28' Flying Cloud
Lower Alabama
, USA
LEDs as first step.
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
05-14-2015, 07:29 AM
Full Time Adventurer
2007 27' International CCD FB
Nomadic
, USA
I thought AGM's typically had less amp hours for the same size as their wet cell counter parts. This has been my experience.
Also, LED's first.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
