Old 02-28-2005, 10:20 AM   #1
LuminumTraila's Avatar
2006 19' Safari SE
NW of Boston , Massachusetts
Thumbs up AGM battery question
The '76 Safari we brought home last weekend has a new (less than a year old) Absorbent Glass Mat battery in it. I thought I read somewhere that in colder climates the battery should be taken out and stored thru the winter. Should I take the battery out of it now and store it until spring? The battery has not been removed at all this winter, so are we too late anyway?
-Jamie
LuminumTraila is offline   Reply With Quote
Old 02-28-2005, 05:06 PM   #2
Images: 59
Jamie,
AGM batteries are less susceptible to freezing than regular wet cells, and have a lower self discharge rate. It should be alright if you check the charge once a month.
Old 02-28-2005, 05:10 PM   #3
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
-Jamie
Jamie,
Any battery will appreciate being protected from both extremes of temperature, cold or hot.
If you're not able to plug the trailer in occasionally to keep the battery charged, then removing it and taking it home might be a smart way to prolong it's life span.
There are many battery threads on this forum, a search will reveal all sorts of additional information, as charging voltages etc.
If the battery is in overall good condition, then I doubt that it would be damaged already.
I recently removed my Interstate sealed battery from my trailer, and even though the lights were still bright and the tongue jack was moving as usual, it was discharged substantially ( 12.3V) . I charged it for a full day with a 6-amp charger, and after 10hours the charge rate went way down, to below 1A, while the volage went to 13.6V, according to my volt meter.
Uwe
www.area63productions.com
Old 03-01-2005, 04:56 AM   #4
2006 19' Safari SE
Thanks for your help. We'll leave the battery in now since we'll be working on the trailer and can re-charge the battery occasionally. Next fall we'll consider taking it out for the winter.
Battery Location uwe 1970-79 Tradewind 23 12-02-2015 07:41 AM
Battery Dead - Again & Again eraffety Airstream Motorhome Forums 10 11-01-2002 11:03 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
Dumb question - 345LE - does the gennie charge the auto battery? williamhenshall General Motorhome Topics 6 08-26-2002 05:49 AM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
