01-31-2015, 04:55 PM
AGM Batteries and Converter question
Just took our new 2015 25' Silver Cloud FB for it's 1st outing. Love the trailer!
But a question about the standard AS converter - which I realize is a 1 stage converter - ie; boat anchor. So I definitely plan to replace it.
My long term plan is to install solar and possibly AGM batteries.
bestconverter.com recommends the PD 4655 upgrade kit for around $200. The huge positive is that this unit replaces the current unit, thereby saving space. The only downside that I see is that there is no temperature compensation option.
If you look at Lifeline's website they recommend Absorbing Voltage from 15.8V (@ 0F degrees) to 13.0V (@ 120F) and Float Voltage of 14.8V (@ 0F) to 13.0V (@ 120F).
An alternative would be to replace the AS Converter with a Xantrex Truecharge2 40amp. Positive = temperature compensation. Negative = $320+ cost AND it would be a separate unit which would take up some space.
So my question is - how sensitive are AGM batteries to temperature? ie; do they really need the temperature compensation? Will a converter with no temp compensation lessen the AGM battery life?
01-31-2015, 06:10 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Welcome Aboard....
RKL,
First.... Give Randy a call at Best Converter
He will answer all your questions.
My experience...our first converter upgrade was a Xantrex 55a, it failed on our first trip.
Randy replaced it with a IOTA DLS 55a IQ4. No temp compensation but it has worked flawlessly on our grp27 100ah Lifelines for 7 years now.
01-31-2015, 07:37 PM
Robert - Randy had assured me it won't be an issue. With your experience, seems like the PD 4655 upgrade kit is the way to go.
Txs, Rasjad
02-01-2015, 03:13 PM
Winemaker
2022 25' Flying Cloud
Avila Beach
Would using the Magnateck/Parallax upgrade kit be ok? It's stated as a three stage converter at ~$200. I have read someone on the Forums say they installed the upgrade in 20 min. It comes in 45 or 55 amp.
02-01-2015, 03:35 PM
I have a 1973 Argosy
So I don't know about new Airstreams, and should probably shut up
But I am very surprised that the new Airstreams come standard with a one stage charger
02-01-2015, 04:21 PM
Naples
Your BEST choice, especially considering your future intent to add solar, would be a Magnum inverter/ charger.
Full temperature compensation, a special charge profile just for Lifeline AGMs, full adjustability for size of battery bank ( absorb time), MADE IN USA and fully field serviceable and 2/3 year warranty, depending on which unit you buy.
MOST, if not ALL RV electronics from China (and this specifically includes Xantrex) are NOT repairable and are throw aways.
Your money, your choice.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
lewster
02-01-2015, 04:26 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Lew,
Is this the one?
Txs, Rasjad
Yes it should work just fine.
Our Lifelines are 7 years old, have been on the IOTA DLS since new,(in the basement for Winter now).
I winterized the beginning of November, checked them yesterday, still holding at 12.9v.
Good Luck
02-01-2015, 04:42 PM
2020 Classic 33
Box Elder
, South Dakota
If you go the Magnum route check the prices at iMarine.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NØVPN
02-01-2015, 05:35 PM
Cris
2013 27' FB International
Las Vegas
, Nevada
Comments on Magnum Tech Support
OK -- Commercial time for Super Bowl, so thought I would check to see what's on AirForums.
In November 2014, we were just setting up after driving all day, and my batteries were way down. Hooked up to power and noticed that batteries were not charging. Since it was 4:45 PM, I quickly called Magnum customer support and explained my problem. Tech support patiently walked me through every step in the diagnostic process. Though they usually close at 5:00 PM, they stayed on the phone with me for an hour. About 6:00 PM, they told me that we had exhausted every check, and although rare, it appeared that the unit MS2812 had malfunctioned. They then asked for the zip code where I was located and said that they would arrange for a replacement the next day. Since we were going to a wedding the next day, I thanked them for all their assistance, and said that we would just go to a hotel. Having made that decision, my wife suggested that we walk back through the steps because "I seemed a little stressed by the whole thing". I begrudgingly said OK, and started out through the checklist. Wouldn't you know, the breaker on the sub-panel had tripped (probably some time way before that trip) -- and in my haste, I didn't check it properly. Flipped it back to "ON" and the Magnum worked as it did the day it was installed.
We all occasionally have these moments, but the bottom line is that despite my panic, Magnum Energy was absolutely fantastic in their customer support.
Cris -- A believer that the extra cost of a great product always fades from memory while you enjoy it's benefits....
02-01-2015, 06:24 PM
Naples
Originally Posted by ROBERT CROSS
Lew,
Is this the one?
Good Luck
Big unit! You really don't need a 2800 watt inverter unless you have large electrical loads that you want to power. Most large motor homes use a MS-2012, 2000 watt unit with a 100 amp charging section. It will easily run any microwave or other load, less a roof A/C of course.
If you don't want or use a microwave, then the smaller MMS-1012 with it's 50 amp charging section will do wonders for your batteries and still give you 8.3 amps of 120VAC into the trailer.
lewster
02-02-2015, 06:53 AM
The 2015 AS we have has a 1000w inverter already. In our previous AS we had a Magnum inverter (a 200W model) which worked great. Our current unit doesn't have a microwave (we never used it) so we think the standard 1000W inverter will work fine.
Here's the link at bestconverter.com which discusses replacements for the standard AS converter:
Airstream Univolt
I definitely plan to add solar. I'd like to keep the batteries outside in the battery box behind the LP tanks. That means keeping the standard wet batteries (only 168AHrs total), or POSSIBLY using Lifeline GPL-6CT 6V batteries which would give me 300AHrs. The footprint is a little different than standard Group 24 batteries but should fit. However it will mean adding a 4" "lip" to the top of the box as those batteries are 13.02" tall instead of the standard 9.25" tall for the group 24 batteries. I'm not sure that there's room to add the lip as the AS front wall tilts out slightly there.
Has anyone out there either added a lip to the standard box or replaced the battery box to accommodate larger batteries?
02-02-2015, 11:51 AM
TinCan
2016 30' Classic
Apache Junction
Why don't you just go with AGM's since those would fit?
TinCan
02-02-2015, 11:56 AM
Naples
The GPL-6CT, 6 VDC AGM batteries will fit your existing battery box foot print, but the additional height will impact the cargo door's opening range and will restrict access.
Why not place them inside? Further back toward the axles with less effect on tongue weight?
Lew Farber
541-490-6357
lewster
02-02-2015, 07:43 PM
2009 28' International
Pacific Palisades
We added AGM's to the battery box, and added a small lip around the top and remounted the cover--it works fine. But Lew, as usual, is right--why not out the batteries inside the coach and farther away my from the coupler? AGM's are designed for interior use on aircraft and boats. Our AGM's are part of a 4 battery bank, (two inside) and after four seasons, we are now asking Lew to replace all four with a much smaller and lighter lithium battery bank inside to get weight off the coupler. At 65lb/battery, we will be replacing 260 lbs ofAGM's with 85 lbs of lithiums. You could use an even smaller, lighter and less pricey lithium battery bank and get the same useful storage as your pair of 6v AGM's. The primary drawbacks are price (twice as expensive) and the fact that you must not charge them when they are below freezing. The price is offset by longevity (they cost twice as much but last 2.5 times as long). So if charging in cold weather is NOT an issue, this may be the way to go.
02-02-2015, 08:26 PM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
We installed four Lifeline GPL-6ct (6Vdc and 300 amp hours each wired serial and parallel for 12Vdc and 600 amp hours as a group) batteries in a custom box above the factory battery box. The factory box with a very modified lid became the home for the BrakeRite II SD electric/hydraulic pump for our disc brakes.
When Lew Farber thinks the new style Lifeline lithium ion batteries are ready for prime time, we will install them and greatly lower our existing tongue weight.
02-03-2015, 06:36 AM
Naples
Switz,
AM Solar is assembling their own lithium ( LiFePO-4) batteries as single units in multiples of 100 amp/ hours. They are complete with their proprietary battery monitor system and cell balancing electronics.
Only problem we are facing now is the shipping. They are considered hazardous materials and require special shipping protocols. AM Solar is working on that aspect to make them more available, but the batteries ARE ready!
A 400 amp/hour lithium pack will give you up to 320 usable amp/hours at a constant voltage (no voltage sag) and would weigh in the neighborhood of 120 lbs.
Lew Farber
541-490-6357
lewster
02-03-2015, 11:16 AM
Winemaker
Avila Beach
I would beg to differ on the subject of putting AGM's inside. There are conditions where, even though they are sealed, will outgas. They have built in over pressure releases. I personally would resist putting any std. lead/acid or AGM in the passenger compartment.
02-03-2015, 12:15 PM
Naples
While this is technically true, it would require quite a catastrophic charging event to cause the one way valve in a Lifeline ( I don't use any other AGM and will not vouch for their product quality).
A Lifeline will require extremely high voltages above 15.5 VDC or a thermal runaway condition to cause this valve to open and vent. Proper charging is KEY to preventing this condition from happening.
I have installed over 100 Lifeline AGM battery systems in the past 10 years and have never had a client experience an open valve condition. I have not even experienced a bad battery in all of those installations either.
Possible.......yes, but with minuscule odds of occurring.
Lew Farber
541-490-6357
lewster
02-04-2015, 06:23 AM
I found this link in which Ktholin added to the bottom of the battery box. His post is at the bottom.
http://www.airforums.com/forums/f449...ox-124163.html
I could add up to 4" on the bottom and that would be the level of my spare tire. That would give me the option to either go with the Lifeline AGMs (300AHrs) or 2 Trojan T-145 (287AHrs) at about 1/2 the price. Hitch wt isn't an issue for my TV.
I'ld prefer not to place AGMs inside as I don't want to use up precious storage space (which ASs seem to all have a lack of).
