11-12-2019, 04:02 PM
#61
2019 30' Classic
Rockwood
, Maine
So just curious here, we are putting the airstream in temporary storage for six weeks, so I decided to unhook the batteries for this period, unhooked the negatives on both batteries and still noticed all electrical lights still working. How does this happen? The unit was still getting solar to the panels, but I am definitely confused? Both negative terminals are unhooked from the batteries? Not hooked to ac power, I am a novice on power but???
Does the solar panel still power the investor somehow?
11-12-2019, 08:33 PM
#62
2019 30' Classic
Canfield
, Ohio
If you follow all the red leads coming from the trailer to the batteries, they all have to come off. That said, I would remove all the black leads instead. Less chance of accidentally shorting one of those red ones!
"At some point, throwing money at the problem *is* the right answer", Uncle Bob
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
Tom & Doty
2019 Airstream Classic 30 Twin
11-13-2019, 04:17 AM
#63
2019 30' Classic
Rockwood
, Maine
Turk, I did unhook all black leads from the negative terminals on both batteries, lights still worked in the trailer, lift jack did not.
So my conclusion was solar panels , when getting light must still feed the system to run the interior dc functions even with the batteries disconnected. But again, I have a real basic understanding of this system, so it may have been something different than that conclusion lol
11-13-2019, 05:13 AM
#64
2017 16' Sport
N/A
, N/A
AGM batteries already bad?
maybe possible the system is grounded somewhere that completes circuit? I would use electrical tape on each wire to ensure no accidental connectivity.
[emoji631]
11-13-2019, 05:50 AM
#65
2019 27' Globetrotter
McHenry
Pulse Tech chargers will desulfate a battery
Originally Posted by UncleBad
Would be interesting to know more about that special charger.
UncleBad and Gregsh, Pulse Tech makes a battery maintenance charger that will desulfate batteries. In fact, their primary customers are the military and commercial users.
I have my two AGM LifeLine batteries connected now. Once the charging is complete it goes to float mode so no worries about over-charging. The unit will continue to pulse (desulfate) and monitor the batteries.
Check out the testimonials online about how they’ve revived dead batteries like Gregsh’s: https://www.pulsetech.net/
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
11-13-2019, 06:39 AM
#66
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
Indeed the solar (with the stock setup) will quite happily fire up without the batteries present. Things will run right up to the point the sun goes behind a cloud and then it all stops. Putting the use / store switch in the "store" position stops most of this nonsense.
11-13-2019, 06:46 AM
#67
2019 30' Classic
Canfield
, Ohio
Hi
I didn't know that! Interesting. A good reason to put in disconnect mode even when the manual disconnect is on.
Tom & Doty
11-13-2019, 07:26 AM
#68
2018 27' Tommy Bahama
Marana
Thanks! Don’t see the one you have on their site however? I have the same AGM’s so would be interested in the same maintainer if I can find it.
2018 27FBQ Tommy Bahama - "Indecision" w/Blue Ox SwayPro, Centramatics, Dual EasyStarts, Airstream Connected, Airtug Trailer Tug HD
2012 F250 6.7 Powerstroke King Ranch - "Earl", Centramatics, Viair On Board Air
11-13-2019, 07:44 AM
#69
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
All of these "battery rejuvenators" should be used sparingly. Used on a regular basis, they will shorten the life of the batteries.
11-13-2019, 09:04 AM
#70
McHenry
Replacement for Dual Station
UncleBad, I just spoke to Rick Gregory at Pulse Tech about the Dual Station. He said it’s two of their single units in one housing and they did not sell enough to justify continuing to produce it.
He said the replacement is the XC100-P Xtreme Charge single charger-desulfator. You could use one then swap when finished or purchase two units.
https://www.pulsetech.net/xc100-p-xt...esulfator.html
It’s currently available from Amazon for $70:
https://www.amazon.com/Pulsetech-Xtr.../dp/B00BPF0Y64
Here’s the charger manual if you’d like to check it out:
https://www.pulsetech.net/amfile/fil...product/15097/
2018 FC23FB
WBCCI# 10258
RETIRED!
11-13-2019, 09:11 AM
#71
McHenry
Hi
Bob, that’s contrary to Pulse Tech’s claim. Their research shows a properly desulfated battery will last up to 3 times longer while maintaining capacity.
“ Eliminating sulfate buildup from lead-acid battery plates improves battery performance and extends battery life up to 3 times.”
https://www.pulsetech.net/our-techno...echnology.html
I respect your opinion but trust the guys at Pulse Tech and the testimonials of their military and commercial users. Your mileage may vary.
2018 FC23FB
WBCCI# 10258
RETIRED!
11-13-2019, 09:36 AM
#72
2019 30' Classic
Rockwood
, Maine
Hi
Uncle Bob, thank you clearing up that mystery.
11-13-2019, 10:50 AM
#73
1994 30' Excella
alexandria
, Kentucky
JeffMC306,
Do you know if the Pulsetech can maintain/charge two 6v batteries connected in series?
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
11-13-2019, 11:21 AM
#74
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
, Texas & Wyoming
Doesn't a 4 stage converter like from PD or Boondocker prevent calcification and protect/tend your batteries automatically anyway?? According to folks I talked with and data I read, seems they are advertising this capability. Why would you need anything else?
11-13-2019, 02:43 PM
#75
McHenry
Yes! Can connect two 6V in series with Pulse Tech
Originally Posted by crispyboy
JeffMC306,
Crispboy, I just called Rick at Pulse Tech to confirm and he said yes, you can use one 12V Pulse Tech charger connected to two 6V batteries tied together in series. The charger will see it as one 12V battery.
Also, I asked how long you can safely leave the Pulse Tech connected to batteries and he said “the longer the better”. Once a battery reaches 100% charge, the unit goes into float mode and it will continue to pulse.
If the battery discharges, the charger will kick into charge mode to top it off. In other words, there’s no risk of frying a battery as long as you maintain the proper water level for non-AGM batteries.
2018 FC23FB
WBCCI# 10258
RETIRED!
11-13-2019, 03:04 PM
#76
McHenry
Hi again Gypsydad,
I looked at Boondocker but cannot find any reference to the pulse desulfinate function like Pulse Tech. They claim to be the only chargers with the technology; not sure if it’s true.
Check out the photo of plates over time for untreated and pulsed. Pretty impressive results. Kind of like dentures with Polydent cleaner!
2018 FC23FB
WBCCI# 10258
RETIRED!
11-13-2019, 03:11 PM
#77
McHenry
Disconnect panels at the 3 Port roof cap?
[emoji631]
That makes sense. What if you disconnect the solar panels at the 3 port rooftop cap? That would remove the potential of power going back to the battery box when batteries are removed. Just remember to reconnect in the spring
2018 FC23FB
WBCCI# 10258
RETIRED!
11-14-2019, 06:28 AM
#78
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
I have yet to see a battery booster outfit tell you their gizmos are anything but wonderful. They are in the business of selling you their product.
Bashing at the batteries with one of these will wear out a new battery. On a 10 year old battery, there's not much left anyway. 90% of what these guys sell is used on old worn out batteries. When they come up with this or that claim, it relates to a battery that is already near dead.
11-14-2019, 07:33 AM
#79
Marana
Thanks for the research!
I am going to give it a try. I have the original AGM’s that Lifeline told me were “bad” and the battery in WarPig, my 1980 F250 beater, is starting to go south. Batteries here in Arizona seem to go quicker due to the heat.
I will report back.
11-14-2019, 09:57 AM
#80
, Texas & Wyoming
Hi again Gypsydad,
I think it is the "equalization" mode (4th stage) that this feature is supposed to provide desulfication capabilities...like on the Progressive Dynamics converters who mention this also. I went with this Boondocker 55amp model couple years ago and it is working fine for now, except sometimes the fan seems to run a bit more then the PD model my friend has. If I need to change out the converter again, I will check out Pulsetech...did you compare with the PD models?
