Old 05-16-2007, 08:46 PM   #29
New Borockton , Alabama
Images: 21
Pat, you have it well said, and lots of great info in this thread from others too.
Lew, that was a great way to explain the starting voltage although that it regulated. I think the low resistance actually allows more initial amperage with the same voltage, don't ya think?
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Old 05-16-2007, 09:33 PM   #30
2004 25' Classic
West Chazy , New York
Lew,
Thanks for your response. Do you think that it would be wise to go with AGM's with the stock charger? What damage could be done to AGM's by overcharging?
Thanks...
Ron
2004 Classic 25 - The Silver Sausage
2008 Silverado LTZ CC 2500 4x4 Duramax - Brutus
WBCCI 2623
romap is offline   Reply With Quote
Old 05-26-2007, 05:54 PM   #31
lewster's Avatar
Naples, FL , Hood River, OR
Originally Posted by romap
Lew,
Thanks...
Ron,
A single stage charger in effect puts 14.2-14.4 volts to the battery all the time. The beauty of the 3 stage units is that after reaching a certain charge level....say 80%, the charger automatically drops the voltage for the 'acceptance' charge, and further reduces it at a higher state of charge for the 'float' charge. Some folks might call this last charging state the 'trickle' charge.
AGMs should be removed from the charger once they are fully charged to around 13.2 volts. Even though they have no free liquid electrolyte, the acid that is fully absorbed in the glass sponge WILL GAS thru the vent if the battery is overcharged and potentially damage the cell.
Hope this is clear. Just another reason to use a 3-stage charger......you don't have to worry about the battery state.......it's all automatic!
Old 05-26-2007, 06:12 PM   #32
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Ron, I don't know how many batteries you have but if you are going to be buying multiple AGMs, ($200-300 each) the expense of a new converter (charger) isn't that much more. ($200 plus or minus).
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 06-03-2007, 04:06 AM   #33
Agree with you Randy on this statement. I believe lewster's meaning was internal leakage instead of internal resistance. Am I right lewster?
Live and LET live
FrenchBern is offline   Reply With Quote
Old 06-03-2007, 06:23 AM   #34
lewster's Avatar
FB,
You are right, but they are the same thing....just terminology. Ohm's law states that: voltage (E) = current (I) X resistance (R) so a battery with lower internal resistance will accept a greater current at any given voltage.
It is the internal resistance in a battery that causes it to self-discharge. The greater this resistance, the quicker the charge dissipates.
Trailer Batteries 83Excella Electrical - Systems, Generators, Batteries & Solar 8 02-04-2013 10:57 PM
Batteries & Solar Charles Q Treichel Generators & Solar Power 2 12-02-2008 12:06 PM
Upgrading batteries Les Gilliam Electrical - Systems, Generators, Batteries & Solar 5 10-16-2002 11:58 AM
Batteries..All about batteries FrankR Batteries, Univolts, Converters & Inverters 0 07-17-2002 09:05 PM
Where should I install new batteries? Andy R Electrical - Systems, Generators, Batteries & Solar 3 03-31-2002 10:01 PM
