Old 04-29-2012, 04:48 PM   #15
tpi
Trabuco Canyon , California
I have West Marine AGM, four years old. If for no other reason than they're the first four year old lead acid battery I've owned of any kind which has stayed entirely leak free, I love them. They are perfectly clean and dry. There is no acid splatters, corrosion, maintenance at all in the battery area (!)
Next time I'll go to the Lifelines. Question: Will the late model battery box take anything bigger than 24? Evidently not, but just checking...
tpi is offline   Reply With Quote
Old 04-29-2012, 04:58 PM   #16
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
tpi,
In our 2008 25', Lifeline Series 27 fit if you cut back the lip under the hinge for the door. The door hinge comes off easily. Cutting back the lip is a bit more work. A Sawzall with a carbide blade would work. Bigger batteries than those may require raising the door.
But all battery brands of a series are not necessarily the same size, so check dimensions of them before you buy them.
Gene
Old 04-29-2012, 06:49 PM   #17
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
I also have Lifeline 27's in our 04 Classic, in this style box. The HB optional.
Name:	AFTER, WITH A LITTLE HELP.jpg
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 04-30-2012, 06:12 AM   #18
bluegrass's Avatar
2007 34' Classic S/O
Buffalo , New York
Lifelines Group 24 Installed
I finished installing the Group 24 Lifelines in my 2005 Safari. They fit perfectly and all the connections were inline with the original batteries-no retro fits necessary. As someone said, there are "secondary" connections on the main posts to accommodate the jumpers and the "hot" wire to the trailer systems. It is a perfect match to the 3 stage converter I installed at the end of last season. I used a small piece of metal with a hole drilled in the middle to hold the batteries in place with the retaining bolt between the two batteries (the original wing nut was too large and prevented the compartment from closing)
Thanks for all the help everyone!
"some say he found the fountain of youth, but didn't drink because he wasn't thirsty......stay thirsty my friends....."
bluegrass is offline   Reply With Quote
Old 04-30-2012, 09:13 AM   #19
Master of Universe
Gene's Avatar
I did the same thing as bluegrass did to hold down the batteries properly, except I cut a round piece of plywood. I had scraps, easy to cut and doesn't conduct electricity.
Gene
Old 04-30-2012, 09:17 AM   #20
tpi
Gene were you able to use the plastic tray in the bottom with your 27s?
Old 04-30-2012, 12:52 PM   #21
Master of Universe
Gene's Avatar
tpi, no. It was too small for the batteries. It protected the battery box from acid spills I suppose, but with AGM's not necessary.
Gene
Old 04-30-2012, 05:17 PM   #22
bluegrass's Avatar
Buffalo , New York
plastic trays
I did use the trays without issues...
Old 04-30-2012, 07:17 PM   #23
Master of Universe
Gene's Avatar
But I put in series 27 and you did series 24. 27 is bigger and didn't fit on the tray.
Gene
