07-16-2014, 07:19 PM
Garfield
, Arkansas
Adding water to batteries in a Classic
Newbie here - I want to check the water level in my batteries on a 2006 Classic but I can't get the stupid things out of their compartment! Is there a trick or do I just need a little more muscle?
07-16-2014, 07:26 PM
2009 30' Classic
Melbourne, FL
, Searsport, ME
My Classic is a 2009, but I suspect the battery compartments are constructed the same as your '06. I wedge a long flat-blade screwdriver underneath to create a ramp upon which to slide the battery out. My batteries have plastic handles so I grab the handle with one hand and place the screwdriver under the battery, lever it up over the ledge, and slide it out.
07-16-2014, 07:31 PM
Oswego
The front edges of the door frame are sharp enough that the weight of the batt will cause its case to catch to the point that the frame digs into, or shaves, the bottom of the batt case. That makes it really hard to drag out. Try cutting some milk jug material the same width as the frame opening and slip it under the edge of the batt. It will slide right up and out.
I also cut some pieces of 1/8" plywood the same size as the floor and placed under the batts. This raises the batts to just about the same height as the opening frame.
-Rich-
07-16-2014, 07:53 PM
Garfield
, Arkansas
Great suggestions! Sounds like a good project for my husband this weekend.
07-16-2014, 07:55 PM
Oswego
Another member just PMed me and jogged my memory. Both of us also installed nylon straps around the batteries to provide a pull handle. It helps a lot as well.
-Rich-
07-16-2014, 07:57 PM
2014 23' Flying Cloud
Reed Point
, Montana
F.Y.I. make sure if you add H2O they are at the fully charged rater before doing so........
07-16-2014, 08:26 PM
2009 30' Classic
Melbourne, FL
, Searsport, ME
Good advice as water added to an uncharged or undercharged battery will expand and possible spill over.
07-16-2014, 08:27 PM
1999 34' Excella
Hillsboro
IF the batts need charging, do that OUTSIDE the AS... REmove the batt and set in safe place, properly fill with DISTILLED water... Charge appropriately...
PS>.. as long as you have water 'covering' all the 'cells' and a little extra.. say about 1/8" deeper than the cell...then charge.
You can put a piece of heavy cardboard over the lip/edge of the door opening to help not 'catch' or drag/shave on it.. Another option, carefully sand paper or file the edge.
Make SURE you do NOT let the terminals on top of the batt come in contact with the frame of the AS... you should not weld on your AS....like that anyway.
Carefully reinstall.
Peace and Blessings..
Channing
WBCCI# 30676
07-16-2014, 08:34 PM
2011 34' Classic
Westchester Cty.NY
, / Miami FL
make sure the water level is above the plates before charging and top off after fully charged.
make SURE the positive post does not touch the door frame! (more use for the cut up jug.)
channing types fast! lol
Ricky
07-16-2014, 08:38 PM
1999 34' Excella
Hillsboro
Thanks Rich!! I do type fast, on the pc.. but I have a real reading issue..
I missed the part about the 'jug'!!!! If someone has an old shampoo or other heavy plastic...
Channing
WBCCI# 30676
07-16-2014, 08:48 PM
Naples
Switch to AGM batteries and you'll never have to deal with this issue again!
lewster
07-16-2014, 09:07 PM
Reed Point
, Montana
AGM batteries are great within a closely controlled charging system otherwise they don't provide the flexibility of wet cell batteries. Most of the A/S that I've come across don't have multi-stage chargers/inverters and tend to overcook the AGM batteries.
07-16-2014, 10:31 PM
Naples
NEWS FLASH!!!!!!
Airstream's OEM single stage, constant voltage Parallax converter will under charge and/or 'overcook' just about ANY battery! All lead acid batteries require 3-stage charging for proper battery life, although the voltages change depending on the battery manufacturer. Most liquid lead acid batteries require a bulk and absorption charge of between 14.4-14.6VDC and a float charge between 13.2-13.4 VDC, NOT the continual 13.6 VDC of a Parallax. AGMs require less voltage due to their significantly lower internal resistance, but all batteries benefit from a 'closely controlled charging system', not just AGMs.
lewster
07-17-2014, 07:40 AM
Oswego
Lewster is, of course correct. However, AGMs just don't pay out on a cost basis for me YET. With a proper 3 stage charger (Iota w/IQ4 in my case) and a desulfator (controversial benefit) my lead acid batts are performing well over 4 years so far and show little sign of degradation per Trimetric data analysis.
With this setup, I only have to add water when I remove batts for winter storage and in spring before installing.....and VERY little water at that....some cells none.
NOW, when I retire and need more battery capacity due to travel/lifestyle changes...AGMs are on the list.
-Rich-
07-17-2014, 08:58 AM
2013 30' Classic
Greenwood
, Mississippi
OK, so...
I think the letters AGM stand for Absorbed Glass Mat-
That still doesn't make me understand what AGM is...
No water? Hence the designation dry cell battery?
Where is electrolyte stored? On the Absorbed Glass Mat?
My regular ole lead acid battery in my 2007 Toyota is the one that came with it when it was built...
I have heard that AGM batteries are better for a big powerful custom car sound system. Maybe they provide more constant voltage? Maybe they stand up to constant discharging and recharging better?
It's kinda like synthetic oil- I've lived without it all these years...
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
07-17-2014, 10:42 AM
Reed Point
, Montana
This forum is full of people's opinions.....that's fine. But it's never acceptable to be rude and or condescending.
07-17-2014, 12:28 PM
2013 30' Classic
Greenwood
, Mississippi
Not my intention at all.
Just stating my curiosities and hoping someone can answer my questions.
The primary reason I have ever considered an AGM or dry cell battery is for high powered car stereo systems. I still don't understand the technology and I have still never owned a dry cell battery.
Quite honestly, when it is time for a new battery, I find is is easier to come up with $100 or less for an ordinary lead acid battery than $170 or more for a dry cell. If anyone could convince me or teach me why AGM batteries are really better...
If anyone could make me understand the technology...
If anything, I was attempting to be silly.
Rude? Condescending? Not at all my intention- I just learned today that AGM stood for Absorbed Glass Mat- I don't a bit more understand it now than before I knew what it stood for...
TAC #MS-10
Airforums #70955
07-23-2014, 06:44 AM
1995 30' Excella
Bowie
, Maryland
Well, for one, I've never checked water levels in mine. They're sealed. With a good converter to charge and maintain them, it's plug them in and forget about them for the next 5 years or whatever. To me it's worth the extra money to reduce regular maintenance requirements and simply not have to worry about the batteries at all.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Adding batteries to a '74 Argosy 22 rear door
Savage68 |
All Argosy Trailers |
6 |
06-06-2013 06:02 PM |
Adding BD time, more batteries
altamont |
Batteries, Univolts, Converters & Inverters |
22 |
04-24-2013 10:13 PM |
Adding additional batteries to tow vehicle
clicker187 |
3 |
12-13-2012 10:06 PM |
On adding batteries, inverters, etc., to tow vehicle
Jammer |
Electrical - Systems, Generators, Batteries & Solar |
15 |
01-13-2010 03:09 PM |
Adding two batteries to the tongue to increase boondocking capacity
hshovic |
24 |
01-09-2008 06:04 PM |
